What did I buy?
Old Dec 21, 2023 | 01:58 PM
rothlane'68's Avatar
Question What did I buy?
I picked up this 68/9 lower stone shield (maybe its called something else, but its the it this plastic piece that bolts under the core support) the other week.
It has these wings on the side that are obviously factory, but Ive never seen before. The seller said this was standard and bolts to the inner fender. But I don't see them in the assembly manual for my 442 and I don't really cant imagine where they would bolt up. The car is away for paint, so I cant hold it up to look where they might fit either...
Is this for a big car? Delta 88 maybe with that wavy front bumper???
Old Dec 21, 2023 | 02:04 PM
442mark's Avatar
Those side wings are 68 A-body Olds only. They screw onto the bottom front edges of the fenders. If your car isn't a 68, just remove them.
Old Dec 21, 2023 | 02:20 PM
tru-blue 442's Avatar
Old School Olds
You may be surprised how many are missing from the 68's. They should be worth a few bucks from the guys looking for factory correct.
Old Dec 21, 2023 | 02:38 PM
Very cool, mine is a 68 and they were missing! Did have the center piece, but cracked pretty badly.
Do they seal to the bumper or just sort of hang there? I'll plan to install them when the car goes back together.
Is this what the confusing third bolt hole (that I think I remember seeing) in the fender is for?
Old Dec 21, 2023 | 03:28 PM
Old School Olds
There should be pics in the 68 CSM, unfortunately, I don't have one of those.
Old Dec 22, 2023 | 08:06 AM
allyolds68's Avatar
They are shown in the 68 Assembly Manual in the upper right corner, below. They were omitted on W30's and W31's because they conflicted with the scoops. They're usually missing because almost every one of them get the outboard mounting holes torn out and there isn't any good way to mount them once that happens
Old Dec 23, 2023 | 08:07 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
The highlighted part is rubber. It tucks up on top of the bumper. That outer hole on the wing is rather fragile. I used rubber coated washers on both sides of the plastic wings(sandwiched). My bud used plastic washers. I used a longer bolt and backed it with a nut so I could control the torque on the plastic.
72442conv
Jul 20, 2021 08:13 PM
KCastl03
Mar 23, 2021 03:25 PM
Tom442
Aug 26, 2012 05:20 PM
garneyflanch
Jun 28, 2012 09:31 AM
1BAD68"S"
Nov 30, 2006 07:21 PM
