waterpump 455
Old April 7th, 2011, 11:15 AM
dragracer's Avatar
waterpump 455
I was wondering if anyone here can explain what the difference is on the water pumps to a 455? I know that the engine is a 70-72 but there are apparently several different?
Robban
www.lundbergracing.com
dragracer is offline
Old April 7th, 2011, 02:10 PM
Robban
Here ya go:
https://classicoldsmobile.com/forums...p-lengths.html
joe_padavano is offline
Old April 8th, 2011, 05:43 AM
Runner
Joffroi's Avatar
I recently changed the water pump on my 70 SX's 455.
I typed up everything about it if you are interested:
http://www.oldsmobilecentral.com/201...70-cutlass.php
Joffroi is offline
Old April 8th, 2011, 07:28 AM
atkinsom's Avatar
Thank you Joffroi...will add this to my mounting data collection
atkinsom is offline
Old April 8th, 2011, 10:38 AM
dragracer's Avatar
Thanks for the replies, now I know which pump to buy
Robban
Old April 8th, 2011, 10:56 AM
OLDSmobility's Avatar
Here's a breakdown of Oldsmobile water pumps, showing year and application and height, as well as part numbers and casting numbers.
http://www.oldsmobility.com/oldsmo/v....php?f=6&t=391
OLDSmobility is offline
Old April 8th, 2011, 11:15 AM
dragracer's Avatar
Very good site , what is the difference between the pump (5.07) from -68-70 and -71-72?
Robban
Old April 8th, 2011, 01:38 PM
I did just update that page with a little additional information provided by the Feb. 1973 revision of the Oldsmobile Master Parts catalog....however, none of my literature explains the physical differences between the two.
Old April 8th, 2011, 03:08 PM
Robban
I suspect that the early pump has a 1.75" inlet and the later one has a 2" inlet.
By the way, the chart shows FOUR different lengths for water pumps, 5.07, 5.57. 5.95. and 6.07. I'm wondering if the last two are supposed to be the same?
And just so there's no confusion, pump #1247079 for the 1975-76 Omega 350 (4.55") is not an Olds pump. It's a Buick 350 motor in that car. The same pump is used on the Buick 231 V6. Similarly, pump #488377, for a 1975 400 motor, is for a Pontiac 400. Olds did not make a 400 that year, the Poncho motor was used in the full size cars.
Old April 8th, 2011, 05:14 PM
...And just so there's no confusion, pump #1247079 for the 1975-76 Omega 350 (4.55") is not an Olds pump. It's a Buick 350 motor in that car. The same pump is used on the Buick 231 V6. Similarly, pump #488377, for a 1975 400 motor, is for a Pontiac 400. Olds did not make a 400 that year, the Poncho motor was used in the full size cars.
Thanks for the clarification, Joe. I just updated the chart to reflect this info.
Old April 9th, 2011, 12:04 AM
dragracer's Avatar
Thanks for your help.
Robban
Old April 21st, 2011, 12:37 AM
dragracer's Avatar
water pump
thanks for your help, now my girlfriends oldsmobile is working again
Robban
greg pettit
June 4th, 2013 06:55 PM
rustycragars
November 18th, 2009 01:21 AM
MN71W30
August 13th, 2009 04:51 AM
montvaleplace
May 29th, 2009 06:33 AM
wolfman98
February 10th, 2009 05:16 PM
Quick Reply: waterpump 455
