vac hose routing
Old Jan 17, 2020 | 02:24 AM
Thomas Bidwell's Avatar
vac hose routing
Hello members, does anyone know or have pictures of vacuum hose routing on 68 W30 air cleaner? service manual does not show pictures of starting point from manifold to vac. units on air cleaner, or how they are connected. thanks in advance for any help. Tom
Old Jan 17, 2020 | 02:44 PM
Gary's 2 442-S's Avatar
Gary
Take a look at this post. maybe it helps you get an idea.
https://classicoldsmobile.com/forums...stions-134485/
Old Jan 18, 2020 | 03:47 AM
rob1960's Avatar
I found this in the assembly manual for a single snorkel air cleaner. You have to put a plastic tee in to tie both snorkel flappers together. Make sure the vacuum actuators still work. I bought a repop air cleaner from the parts place. The first one I got had horrible paint & I sent it back. The second one I got only the flapper on the pass side worked, the drivers side wouldn't hold vacuum! I wasn't about to send it back again since the A--holes never refunded my shipping costs!!! I have all the lines on it but I just don't have it hooked up to the manifold fitting, you can't see it when it's on the car. They've had tons of problems with the repop air cleaners, the price pretty much doubled in the last year. They were around $400 for years, now they're over $700 if you can get one!
Tjohn8573
Apr 8, 2019 12:22 PM
hueveaj
Oct 29, 2013 12:53 PM
Jimoldsfan
Mar 2, 2013 11:47 AM
mmurphy77
May 24, 2010 01:49 PM
Chumley
Jan 3, 2007 06:00 AM
