Transmission question
Old Oct 8, 2011 | 06:51 PM
DATNFAMOUSRICAN's Avatar
DATNFAMOUSRICAN
I have a 71 Cutlass 4 door and everytime I drive it transmission fluid leaks bad and burns fluid off the pipes I was told its not the seal and its leakin transmission fluid back up the dipstick but I took the transmission out and it was alot of fluid in the stick could it be the pressure from the pump inside the transmission be pumping it back up and once it runs it hesitates to go in gear could anyone tell me what could be the problem?
Old Oct 8, 2011 | 07:14 PM
TripDeuces's Avatar
Sounds like it is over filled or the vent is clogged.
Old Oct 8, 2011 | 07:24 PM
DATNFAMOUSRICAN
How do I unclog the vent or do I have to do some internal work or take it to the transmission shop or I can take a air compressor nozzel and blow in anything I see that has a opening
Old Oct 8, 2011 | 07:34 PM
TripDeuces's Avatar
If you stick anything in it to try and clear it you run the risk of pushing it into the transmission. This goes for blowing air into it also. I would hook a shop vac up and apply suction to it somehow.
Old Oct 8, 2011 | 08:08 PM
DATNFAMOUSRICAN
I might take it to the shop............but I thought about just unbolting those bolts and ish and seeing whats going on myself lol and how can you tell the transmission size when you have 2 of them side byside
Old Oct 8, 2011 | 08:53 PM
redoldsman's Avatar
Proud Viet Nam Veteran
This problem seems to be more common on 4-door cars. Of course I am kidding about that. Hey is is a turbo 350 and there are millions of them still around. I would take it to a reputable transmission shop and see what they say. It can't be the first one that has done this. Good luck.
jensenracing77
Ninety-Eight
Feb 28, 2009 09:13 AM
svt412
Jul 4, 2008 03:37 PM
whizkid88
Jul 1, 2008 07:13 PM
Olds64
Dec 20, 2007 05:10 AM
Cuttyon22s
Jul 10, 2006 11:24 PM
