Tachometer Wiring
Old January 7th, 2013, 09:39 AM
65droptop442's Avatar
Tachometer Wiring
Can I use the factory tach with HEI distributor. How do I wire it? Its a 65 442 with console tach. thanks
65droptop442 is offline
Old January 7th, 2013, 10:18 AM
Sampson's Avatar
Good question. I am getting ready to install pertronix in my dist. Had not thought about the Tach.. Tach is new too so I don't want to burn it up!
Sampson is offline
Old January 7th, 2013, 10:34 AM
HEI distributors have a 'tach' contact. Wire it to that.
Allan R is offline
Old January 7th, 2013, 11:34 AM
As Allen noted, thie is extremely easy. The factory HEI distributor has five male spade terminals in the cap. Three connect to the wire harness from the distributor body. The remaining single terminal on the left is the power (BATT) terminal. The one in the right is the tach feed. This terminal provides the same tach signal as the coil on a point-style ignition system. Just wire the factory tach feed wire to this terminal.
joe_padavano is offline
Old January 7th, 2013, 04:27 PM
allyolds68's Avatar
Sorry to jump in but is the tach input on the MSD 6AL a safe place to wire the tach lead to for a factory tic tac toc? I read the directions and they talk about some ch*vy applications needing a capacitor or something. I'm guessing Olds may or may not be the same
allyolds68 is offline
Old January 8th, 2013, 09:03 AM
Thanks Joe and Allen. I will try to hook up today. Steve
Old January 8th, 2013, 09:26 AM
Can a tachometer be bench tested
Is there a way to bench test a 65 442 tach. I have tried two tachs and both show no signs of working. The needle moves freely when moving around but not when hooked up. Steve
70cutlasssupreme
January 24th, 2022 02:30 PM
alexrains
December 9th, 2009 02:49 AM
oldzy
September 10th, 2009 05:23 AM
wazoo
Hurst/Olds
August 27th, 2009 01:36 PM
Florent.turbo
September 10th, 2008 01:10 PM
Quick Reply: Tachometer Wiring
