Steering gear end cap leak 66-442
Old May 17, 2012 | 10:36 AM
wmlewis's Avatar
I located my p/s steering gear leak at the front/bottom end cap cover.. After
reading the manual I thought I would try and replace the O ring while the gear was still on the car. I removed the shield under the radiator and removed the end cap retaining ring. The manual said to turn the gear counter-clockwise which should push the cap out. The cap did not move. It
appears that the cap is aluminum because when I tried to turn the cap lightly with a small chisel it took a small chip out of the surface without budging. I
looked online for a replacement cap but can't find one for the '66. The leak was so bad that it drained the reservoir in less than a week. Before I do any permanent damage to the end cap before finding a replacement, does anyone have any suggestions or a part number for the end cap. Bill
Old May 17, 2012 | 11:37 AM
wmlewis's Avatar
Never mind..... I added a little p/s fluid and I started the engine and then shut it off.. The pressure was enough to get the cap out far enough... Now all I have to do is go to the hydraulic shop and pic up the O ring.... Thanx anyway... Bill
Del70
Aug 11, 2015 04:27 AM
drjr56
Sep 9, 2012 08:05 PM
vmathy
May 30, 2011 08:50 PM
dynamic88
Drivetrain/Differentials
Mar 22, 2008 10:44 AM
