Slow fuel leak
Old May 5th, 2018, 04:32 PM
EngineErnie
EngineErnie's Avatar
Slow fuel leak
So I have started noticing a fuel leak on the floor of the garage, and it is coming out directly underneath the dust cover on the fly wheel on my 72 Cutlass S 350 engine. I noticed it yesterday and i have checked all the fuel lines from rear of the car to the pump, and from pump to carb. All appear tight. The leak is coming behind the engine, and there is residue on the black fly wheel dust cover.
any ideas what may be causing this?
EngineErnie is offline
Old May 5th, 2018, 05:25 PM
Well its not leaking at the dust cover. You have a leak at the pump or a line and its migrating to the dust cover.
oldcutlass is online now
Old May 5th, 2018, 10:45 PM
Are you sure it's gasoline?
Koda is offline
Old May 6th, 2018, 12:29 AM
Ozzie's Avatar
As mentioned, first be sure it's gasoline, because there is usually no gasoline near there. I suppose it could be a carburetor leak that makes its way down there, but that means there's quite a leak up above. A small leak would evaporate before going that far.
Ozzie is offline
RenderPit
Ninety-Eight
August 6th, 2015 04:55 PM
wolfman98
Site Help
November 19th, 2009 05:06 PM
ztim
July 31st, 2007 12:45 PM
bandit600
November 15th, 2006 06:24 AM
69olds350
November 7th, 2006 07:01 AM
Quick Reply: Slow fuel leak
