Rocket 350 timing
Old December 8th, 2021, 09:12 AM
Jim Kennedy's Avatar
Rocket 350 timing
Hello, I recently purchased a 1976 Cutlass Supreme and today I am checking the timing on the Rocket 350. It appears that the timing is at 8 degrees from TDC... said another way, the line is dead on the fourth "peak" of the indicator tab. MY QUESTION IS: Is that correct, or, is there a more appropriate setting?
In case it was not clear, the engine was updated by someone prior to me with an electronic distributor vs. the points, etc. Further, the vacuum hose is disconnected and plugged and the Old Gal is plenty warm.
Thanks if you have an answer and I'll get back to you if you have a question.
Jim Kennedy is offline
Old December 8th, 2021, 09:20 AM
Which distributor are you running?
oldcutlass is offline
Old December 8th, 2021, 09:24 AM
Delco Remy is what I see stamped into the distributor.
Old December 8th, 2021, 09:27 AM
Is it a large cap hei or a stock points distributor with a pertronix installed? Post a picture of it if your not sure.
Old December 8th, 2021, 09:33 AM
Old December 8th, 2021, 10:14 AM
With the HEI distributor the stock timing settings are n/a. You want to set your timing to 16/18* before tdc. It's hard to do it without a dial back timing light. Then you need to limit your vacuum advance to 10*.
Old December 8th, 2021, 11:07 AM
Thank you. Much appreciated!
Old December 8th, 2021, 12:07 PM
Originally Posted by Jim Kennedy
Hello, I recently purchased a 1976 Cutlass Supreme...
... the engine was updated by someone prior to me with an electronic distributor vs. the points,
While the recommended timing settings are accurate, it should be noted that in 1976 the HEI was the "stock" distributor as points had been phased out by then.
Fun71 is offline
Old December 8th, 2021, 02:42 PM
I didn't even think about the year...
razman427
November 3rd, 2018 03:55 PM
JimmyFL
June 10th, 2017 04:18 PM
HLS
December 27th, 2016 04:26 PM
deadeyejedi
August 14th, 2015 09:16 PM
65cutty
July 30th, 2009 04:04 PM
Quick Reply: Rocket 350 timing
