Rocket 350 timing
Old Dec 8, 2021 | 09:12 AM
Jim Kennedy's Avatar
Rocket 350 timing
Hello, I recently purchased a 1976 Cutlass Supreme and today I am checking the timing on the Rocket 350. It appears that the timing is at 8 degrees from TDC... said another way, the line is dead on the fourth "peak" of the indicator tab. MY QUESTION IS: Is that correct, or, is there a more appropriate setting?
In case it was not clear, the engine was updated by someone prior to me with an electronic distributor vs. the points, etc. Further, the vacuum hose is disconnected and plugged and the Old Gal is plenty warm.
Thanks if you have an answer and I'll get back to you if you have a question.
Old Dec 8, 2021 | 09:20 AM
Which distributor are you running?
Old Dec 8, 2021 | 09:24 AM
Delco Remy is what I see stamped into the distributor.
Old Dec 8, 2021 | 09:27 AM
Is it a large cap hei or a stock points distributor with a pertronix installed? Post a picture of it if your not sure.
Old Dec 8, 2021 | 09:33 AM
Old Dec 8, 2021 | 10:14 AM
With the HEI distributor the stock timing settings are n/a. You want to set your timing to 16/18* before tdc. It's hard to do it without a dial back timing light. Then you need to limit your vacuum advance to 10*.
Old Dec 8, 2021 | 11:07 AM
Thank you. Much appreciated!
Old Dec 8, 2021 | 12:07 PM
Originally Posted by Jim Kennedy
Hello, I recently purchased a 1976 Cutlass Supreme...
... the engine was updated by someone prior to me with an electronic distributor vs. the points,
While the recommended timing settings are accurate, it should be noted that in 1976 the HEI was the "stock" distributor as points had been phased out by then.
Old Dec 8, 2021 | 02:42 PM
I didn't even think about the year...
razman427
Nov 3, 2018 03:55 PM
JimmyFL
Jun 10, 2017 04:18 PM
HLS
Dec 27, 2016 04:26 PM
deadeyejedi
Aug 14, 2015 09:16 PM
65cutty
Jul 30, 2009 04:04 PM
