Rear control arm braces
On the street you probably wouldn't notice it but going through a slalom or road course it should be very noticeable. They are designed to tie the control arm mounting points together resulting in less flexing and sway in the whole rear suspension. It also helps frame stability and lessons the chance that you'll tear off that lower control arm mounting point. Although that would take some serious hp/tq but I have seen it happen. Several manufacturers make supports that weld unto that mounting point to strengthen it also.
http://www.tntraceshop.com/1964-1972_A-body_180300.html
MDchanic
31
August 12th, 2012 04:24 AM
oldzy
December 19th, 2011 06:43 AM
oldzy
January 18th, 2011 03:44 PM
oldzy
Suspension & Handling
December 31st, 2010 07:14 PM
