Rear control arm braces
Old Jul 26, 2012 | 05:16 AM
boese1978's Avatar
Are the triangulating bars they sell worth the money in a street machine with a mild build? Do they provide any noticable, improved handling characteristics?
Old Jul 26, 2012 | 07:25 AM
TripDeuces's Avatar
On the street you probably wouldn't notice it but going through a slalom or road course it should be very noticeable. They are designed to tie the control arm mounting points together resulting in less flexing and sway in the whole rear suspension. It also helps frame stability and lessons the chance that you'll tear off that lower control arm mounting point. Although that would take some serious hp/tq but I have seen it happen. Several manufacturers make supports that weld unto that mounting point to strengthen it also.
http://www.tntraceshop.com/1964-1972_A-body_180300.html
MDchanic
31
Aug 12, 2012 04:24 AM
oldzy
Dec 19, 2011 06:43 AM
oldzy
Jan 18, 2011 03:44 PM
oldzy
Suspension & Handling
Dec 31, 2010 07:14 PM
