Ram air hood brackets on a 69
Old Jun 17, 2018 | 06:03 PM
kevdog442's Avatar
Member
Putting a 70 ram air hood on my 69 442. What modifications are needed to install the hood lock brackets on the core support. I’m talking about the twist pins receiver. I have the brackets but don’t see how they mount. Can find any detailed pics, and don’t have a 70 assembly manual since mine is a 69. Any help is appreciated.
Old Jun 18, 2018 | 12:04 AM
Gerald Nickels's Avatar
You must run a 70 core support for the hood to lock right on the safety hook. The hood pins are only for looks.
Old Jun 18, 2018 | 06:58 AM
Now that OAI hoods are on every 70-72, they will now be on every 69.
Old Jun 18, 2018 | 07:58 AM
Rustbucket2's Avatar
They just look cool. Everyone likes the look of a OAI hood ! I think I will put one on my 70 supreme. Now how do I get one on my 64 Vista Cruiser ?
Old Jun 18, 2018 | 08:53 AM
Lots and lots of mud.
Old Jun 18, 2018 | 03:36 PM
kevdog442's Avatar
Member
Was going to modify an extra 69 support that I have. Put the 70 latch in it, but still don’t know about the pins.
Old Jun 18, 2018 | 04:08 PM
2blu442's Avatar
Hi Kevin
There's a depression where the center bolt of the hood hold down brackets goes. Then you may have to drill the other two holes, but this one center hole should get you located. Attached are pictures of the bracket mounted on a 1970, then a 1971 core support without the bracket but showing the depression.
Old Jun 18, 2018 | 04:10 PM
2blu442's Avatar
Let me know if you'd like to see any other views or measurements.
John
Old Jun 18, 2018 | 05:25 PM
kevdog442's Avatar
Member
Originally Posted by 2blu442
Hi Kevin
Thanks John finally an answer that helps, I thought I was on Facebook there for a minute. I don’t think the 69 has that depression but it gives me an idea what I’m working with. That’s the kind of detailed pictures I was looking for.
Old Jun 18, 2018 | 05:31 PM
2blu442's Avatar
Hi Kevin
If you want to modify the hood latch and keep your 1969 core support I think it does have the depression. Here's pictures of a 1969 core support and I believe this is the same location as the 1970 depression. John
Old Jun 18, 2018 | 05:51 PM
kevdog442's Avatar
Member
Hi Kevin
Yeah I guess it does, I had to go out and look at it. Thanks
Old Jun 19, 2018 | 11:06 AM
Chugger's Avatar
I installed a Thornton OAI hood on my 1969. Those depressions in the 69 support lined up the hood pins perfectly.
Old Jun 19, 2018 | 11:45 AM
droptopron's Avatar
delete
To the OP, I'd suggest you call Thornton's and get their input.
Thybigwheel
Body work
Mar 2, 2023 10:07 PM
ctrain22
Sep 10, 2014 09:33 AM
Dcam81
Aug 13, 2013 12:29 PM
Firstcutlass
Body work
Jun 11, 2012 03:03 PM
tru-blue 442
Body work
Feb 4, 2012 04:44 PM
