pre-load on front wheel bearings
Old October 7th, 2013 | 06:38 AM
Sid's Avatar
Sid
I am replacing the front wheel bearings on my 67 cutlass and can't find the spec on torque for the bearings? Thanks for any help.
SID
Old October 7th, 2013 | 07:43 AM
SID
This is something you do by feel. With the wheel spinning, tighten the nut until you feel drag to ensure the bearings are fully seated. Back off until loose then with the wheel spinning, tighten until you just start to feel drag. You may need to back off just slightly from the point to insert the cotter pin.
Old October 7th, 2013 | 07:50 AM
x2 on Joe's procedure.
Old October 7th, 2013 | 08:46 AM
oldspackrat's Avatar
X3 for sure.
junior supercar
Drivetrain/Differentials
27
October 30th, 2013 09:16 AM
oldzy
September 14th, 2010 06:40 AM
mp71conv
December 18th, 2008 12:03 AM
dantana
May 20th, 2008 01:19 PM
Andrew240
December 22nd, 2007 02:54 PM
