Olds Rochester Carb.
29251 (also 7029251) is a 1969 carb. It was used on the 69 Hurst Olds, and I think on other applications as well.
3418 should be a date code, produced on the 341st day of 1968, if I remember correctly.
It's also used on the '69 4-4-2, auto transmission. Sometimes these carbs had the entire 7029251 number written on them; sometimes they just had the 29251, with the two letter broadcast code (RJ) and the date code. This carb is indeed dated the 341st day of 1968 and it is an original carb. Service replacement carbs would have the same part number (7029251) plus a date code and no broadcast code. And the date would most likely be after the 1968 production year.
Joesen
September 29th, 2013 05:44 PM
sanemb
May 28th, 2008 05:43 PM
