Olds Rochester Carb.
Old Apr 1, 2009 | 05:49 PM
slick50's Avatar
I have a Rochester Carb. with the number29251 RJ on it followed by 3418. I was woundering if anyone could tell what engine this Carb. came on.
Old Apr 1, 2009 | 05:57 PM
Cameo White's Avatar
Smile
29251 (also 7029251) is a 1969 carb. It was used on the 69 Hurst Olds, and I think on other applications as well.
3418 should be a date code, produced on the 341st day of 1968, if I remember correctly.
Old Apr 1, 2009 | 08:09 PM
rcorrigan5's Avatar
Randy C.
It's also used on the '69 4-4-2, auto transmission. Sometimes these carbs had the entire 7029251 number written on them; sometimes they just had the 29251, with the two letter broadcast code (RJ) and the date code. This carb is indeed dated the 341st day of 1968 and it is an original carb. Service replacement carbs would have the same part number (7029251) plus a date code and no broadcast code. And the date would most likely be after the 1968 production year.
griffey57
Aug 3, 2015 12:19 PM
Bad68442
Jan 25, 2014 09:06 AM
Joesen
Sep 29, 2013 05:44 PM
Hal Robinson
Feb 24, 2009 08:51 AM
sanemb
May 28, 2008 05:43 PM
