Oil pan modifications
Old May 11th, 2009, 09:47 AM
jlowery's Avatar
Anyone modify your own oil pan with baffles or windage tray set up?
This may have been discussed before but didn't find any thread on it.
Joe
jlowery is offline
Old May 11th, 2009, 09:48 PM
Run to Rund's Avatar
Lots of us have. What is your question? All you have to do is make up cardboard baffles for the front and rear of the sump that will clear the oil pump and pickup, then copy them in sheet steel and get them welded in.
Run to Rund is offline
Old May 11th, 2009, 11:13 PM
Sangersam's Avatar
I have a modifided pan for a 394 set up in a V-drive boat if your looking.
Sangersam is offline
Old May 12th, 2009, 11:05 AM
jlowery's Avatar
I figured this had been done before and was hoping someone might have pictures they could share. Going to modify the pan for increased capacity and wanted to incorporate baffles as well.
Just looking for some ideas.
This is a boat application too.
Joe
jlowery is offline
Old May 12th, 2009, 11:23 AM
ramos7's Avatar
how does having increased oil capacity help? i know some of the newer cadillacs hold 7qts in them
ramos7 is offline
Old May 12th, 2009, 05:25 PM
Sangersam's Avatar
Joe
Hey Joe, I will click off some pics of my pan and put them up for some reference.
Old May 13th, 2009, 05:14 AM
Past Administrator
Oldsguy's Avatar
It is something that has been done to Oldsmobile engines, specially 455s, by re-builders in the past if they have been really pushing the limits. For a stock engine or a standard rebuild it isn't necessary. The increased quantity of oil is to compensate for increased pump capacity which is to compensate for slow drain back to ensure good oiling of the main and rod journals. Kind of a dispute by some people if it is really necessary or if there are other ways to "skin the rabbit". Some people use restricted push rods, some people ream out the drain back passages in the heads, some modify the journals, some do all of the above.
Oldsguy is offline
Old May 13th, 2009, 05:47 AM
2blu442's Avatar
Joe, if this is for your boat motor large pans (12 qts?) with baffles are common. I've had several including factory made like Moroso and others that took a automotive pan and modified it. I'll dig through my photos to see if I have pics of one. You might look at some aftermarket dealers like Summit to see if they have good pictures. John
2blu442 is offline
Old May 14th, 2009, 02:06 PM
jlowery's Avatar
Thanks for the feedback.
This is for the boat engine. Plan on reaming/smoothing the drain holes as well. Looked at the pans from Summit and similar for examples.
The reason I'm modifying the stock pan is clearance issues under the engine to the hull. It doesn't look like an aftermarket pan will fit. Also enjoy hand crafting improvements. Something my dad and grandfather taught me.
Want to keep oil circulating at extended 4500-5000 rpm runs.
Joe
jlowery is offline
oldzy
December 27th, 2010 08:38 PM
jeffreyalman
April 29th, 2010 11:31 AM
diamondave
August 29th, 2008 01:29 PM
jrbarrie83
June 8th, 2005 05:14 PM
Quick Reply: Oil pan modifications
