Need a shop to help with '55 Starfire.
Old Jul 26, 2023 | 08:55 AM
Rickey1964's Avatar
Need experienced help in my area with most everything with this '55 Starfire. Engine, transmission, brakes, powered devices such as top, windows, seats, etc. Nothing works as advertised. My father and I can't seem to get anywhere with it and I'm looking for nearby help. I live in Calhoun, Georgia.
If I have posted this in the wrong forum then please move or call it to my attention. Thank you.
Old Jul 26, 2023 | 09:16 AM
Your post is in the correct forum. Do you want to do the work yourself or find a shop to do it?
Old Jul 26, 2023 | 09:21 AM
While the General forum would probably work, I moved your thread over to the Vintage forum. It's more aligned with your model year.
Old Jul 26, 2023 | 09:33 AM
Rickey1964's Avatar
A shop. I am an otr truck driver and just don't have the time to address these issues. My Dad is a retired auto repair shop owner with tons of knowledge, but this car has him perplexed.
Old Jul 26, 2023 | 09:40 AM
Rickey1964's Avatar
Okay, thank you.
Old Jul 26, 2023 | 10:09 AM
And with the new info I moved it back to the general forum and changed your title.
Old Jul 26, 2023 | 10:28 AM
Rickey1964's Avatar
Gotcha.
Old Jul 26, 2023 | 10:34 AM
rocketraider's Avatar
Oldsdruid
First thing you need is an original print copy of the 1955 Oldsmobile factory shop manual. Not a CD-ROM or pdf file- they lose critical detail.
There are also airconditioning and HydraMatic supplements.
Next- contact the Dixie Olds Club in Georgia. They're concentrated in Atlanta and like most groups heavy on 68-72 A-body but there are some 50s owners in it.
https:/www.oldsmobileclub.org/members/group.aspx?id=190049
A membership in either Oldsmobile Club of America or National Antique Olds Club will help too. They both have 1955 model year advisors.
Old Jul 26, 2023 | 11:19 AM
Rickey1964's Avatar
Thank you.
Old Jul 27, 2023 | 06:45 AM
Rickey1964's Avatar
I ordered the manual.
Old Jul 27, 2023 | 07:32 PM
Tedd Thompson's Avatar
Most of your issues are not that specialized and could be repaired by most shops with a good old time mechanic. Not knowing what does or doesn't work you might have to go to several shops to cover all your problems. Take that motor manual with you and let them know they can use it. Show them a Fusick catalog for stuff they need to know where to get. I know nothing about your local shops or area, I'm from the left coast, but ask around at local car shows, or clubs for good info on decent local shops. Tedd
Old Jul 27, 2023 | 08:53 PM
redoldsman's Avatar
Proud Viet Nam Veteran
You need to find a small shop with an older mechanic. A lot of places won't work on an old car.
Old Jul 28, 2023 | 04:15 AM
BillK's Avatar
Are there any regular "cruise ins" in your area where car guys gather on a regular basis ? If so go to one and ask around. Those guys will know if there are any decent shops to work on vintage cars.
Also, edit your post and add your location in the title.
Old Jul 28, 2023 | 08:07 PM
Rickey1964's Avatar
Thanks Tedd. I need to order that catalog.
Old Jul 28, 2023 | 08:08 PM
Rickey1964's Avatar
Already on it.
Old Jul 28, 2023 | 08:09 PM
Rickey1964's Avatar
Okay, thank you.
Old Jul 28, 2023 | 08:11 PM
Rickey1964's Avatar
Couldn't edit the title of the topic. My location is in my O.P.
Old Jul 28, 2023 | 10:32 PM
Nobody reads those. People post for sale ads thinking the same thing. Take the time people. I know it really hurts your thumb on a cell phone but... Post Where You Are. Don't assume that people are going to check your profile. That is not happening.
Old Aug 3, 2023 | 04:26 PM
Rickey1964's Avatar
I got the shop manual a few days ago. Honestly there wasn't anything on the convertible top motor or troubleshooting in general. It was primarily part rebuilding and installation. Not exactly what I need. I wish I'd never come across this thing.
Old Aug 3, 2023 | 07:04 PM
Oldsdruid
It ought to be in the body section of the shop book.
IDK if there was a separate Fisher Body convertible shop book or not but all five GM Divisions used the same top mechanism and hydraulics, so the info is out there somewhere.
Old Aug 4, 2023 | 12:42 AM
Rickey1964's Avatar
Okay, thank you.
Old Aug 4, 2023 | 07:24 AM
Oldsdruid
The CVT should be the only thing on a 55 that's still hydraulically operated. Windows and seat changed to electric that year.
Are any of them functional? Would help to know exactly what isn't working or performing right and what it's doing.
Oldsmobiles didn't usually get subjected to the electrical buggery and butchery other cars did but your Starfire is almost 70 years old. There's no telling what some yahoo owner or mechanic has done to it over those 70 years.
With a shop book, wiring diagram, basic troubleshooting skills and understanding of hydraulic systems you can get this stuff functional. Don't write the car off yet but don't turn it over to just anyone to repair it. Old car club connections are where you'll find people who can fix it.
Old Aug 5, 2023 | 04:31 PM
Rickey1964's Avatar
I'm more upset than discouraged. Right now we (my Dad and I) are just trying to get the engine operating normally. We have the fuel delivery and carburetor straightened out but it is missing on the 6th and 7th cylinders. We may have to pull the heads off and get a valve job done.
Old Aug 5, 2023 | 05:15 PM
Oldsdruid
Double check the firing order. 1-8-7-3-6-5-4-2. Distributor rotation on these is counter clockwise. You would be surprised at how many people try to use the later 1-8-4-3-6-5-7-2 firing order and order the plug wires clockwise.
Past that, before you pull the heads, pull the rocker covers and observe the rocker arms and shafts at cranking speed. If a valve is sticking, pull the rocker shaft, spray penetrating oil around that valve stem and guide and whack the stem and spring a couple times.
From an old MOTOR's general service manual:
Dwell 26°-33°, timing 5° BTDC at 850rpm with vacuum advance disconnected. Hot idle speed 400RPM in D.
Timing mark.
Same info should be in your 55 CSM. Mine is packed up and the MOTOR's was handy.
Old Aug 5, 2023 | 08:20 PM
There is a supplement for the top, I have one somewhere, but to me, it didn't open up much that wasn't pretty obvious. If you are having trouble raising the top when the pump won't run just remove the lift cylinders (top bolts) and manually pull it up. It's tough and usually takes two people especially if the top hasn't gone up in a few years, lube all the folding joints first... Lost in the fifties.. Tedd
Old Aug 6, 2023 | 06:20 AM
Rickey1964's Avatar
Thanks guys. I will pass this along to my Dad.
Old Aug 23, 2023 | 10:21 AM
Rickey1964's Avatar
Well, to update you guys, we've triple checked the firing order and have that correct. We changed out the plugs, plug wires and other tune-up parts. I purchased the best parts on the market and it's getting plenty of fire. Dad next found an issue with the carb and fixed that. Dad then did a compression check on all the cylinders and found that 6 and 7 have very low compression, about 30 and 60 PSI at idle. So we've pulled the heads off and hopefully I can get them to the machine shop in the next town (Rome, Ga) tomorrow morning. I need to purchase a complete gasket set, checked with RockAuto, who does not have it at the moment. But I should find one without an issue.
Old Aug 24, 2023 | 07:45 AM
Fusick should have a gasket set, always did in the past, but that shouldn't be a problem as those are pretty common parts. Hydro-E-Elictric will have any parts for the top parts, motors or cylinders hoses etc. After a while you will find places to get parts cheaper but at first some of the specialty houses will save you lots of time finding stuff and usually know more about vintage part problems.
I don't know if you have seen an approximate value on that car but in bad conduction #4 it would be somewhere around $15- $20 thousand. You might want to look into it, could surprise you...Tedd
Old Aug 24, 2023 | 08:05 AM
Hydro-E- Electric co, should have any part you might need for the top motors, cylinders, hoses etc. Usually specialty houses are a little more expensive but when you are just starting in the hobby their expertise in these parts are well worth the extra price.
I don't know if you have ever had even a rough idea of the value of a Stare fire but a #4 car is somewhere around $15000 to $20000, it might surprise you... Lost in the fifties ...Tedd
Old Aug 24, 2023 | 09:14 AM
Sorry for the double post, I didn't think the first one went through...Tedd
Old Aug 25, 2023 | 07:20 AM
  #31
Rickey1964's Avatar
We are far from getting to dealing with the top.
Old Aug 25, 2023 | 07:38 AM
  #32
Rickey1964's Avatar
Tedd, Thanks for the information. Yesterday I took the heads to the auto machine shop. Hopefully they will be ready in about 2 weeks to pick up.
Like I have written, very little works, no power to the top, windows, seats or locks. No brakes. Engine running on 6 cylinders. Auto trans only shifts to low gear and reverse. A little rust, but no rust was suppose to be apparent on the car. Not what I paid for. Another thing that is frustrating is the past owner (deceased) was suppose to be one of the top auto enthusiasts in his region of Canada, and a top notch Oldsmobile guy. He owned a hot rod shop in Winnipeg called 'Softy's'. But his so-called 'pride and joy' is an absolute mess, when compared to how it was touted. Oh, it's far from worthless, certainly is worth the #4 condition of the car, which is noteworthy.
We will have the heads back and the engine back together soon. It's not a full-on engine rebuild, just a valve job. Hopefully there won't be any complications and it will start to run properly. Then we can try to look at the other issues.
Oh, one of the exhaust manifolds has a crack, we are going to try repair it. But may end up coming back to here, shopping for a replacement.
70Post
Jan 6, 2018 09:20 AM
rootney
Aug 13, 2013 09:06 AM
ChefDeadpool
Aug 29, 2011 12:29 PM
Toyaholic
Body work
May 16, 2010 05:23 PM
