Having trouble...
Having trouble...
Okay friends I need help. I have a 1971 cutlass supreme with a 350 engine. The alternator belt keep popping. I dont have the belts to tight either. If the pulleys need to be realigned,what is the cost associated with that?
Last edited by Nako29; February 14th, 2010 at 03:47 PM. Reason: Found out what may be the problem,,,
Welcome!
First of all what kind of car are you having problems with?
Has it had any mods done to it?
Did this issue start on its own or after a repair or mod?
If the belt is tight, then belt to pulley alignment is the problem.
Is the steering pump pully secure on its shaft? Perhaps remove the problem belt and check for loose pulleys or shafts.
Welcome to our humble home.
Need pics as usual.
Are all the brackets and the pump and alternator in the correct position with the right spacers and all that?
Could be a belt alignment problem like Beauregard said?
Need pics as usual.
misercola
18
May 3rd, 2010 03:39 AM
