Having trouble...
Old Jan 25, 2010 | 03:05 PM
Nako29's Avatar
Having trouble...
Okay friends I need help. I have a 1971 cutlass supreme with a 350 engine. The alternator belt keep popping. I dont have the belts to tight either. If the pulleys need to be realigned,what is the cost associated with that?
Last edited by Nako29; Feb 14, 2010 at 03:47 PM. Reason: Found out what may be the problem,,,
Old Jan 25, 2010 | 05:30 PM
Lady72nRob71's Avatar
Welcome!
First of all what kind of car are you having problems with?
Has it had any mods done to it?
Did this issue start on its own or after a repair or mod?
If the belt is tight, then belt to pulley alignment is the problem.
Is the steering pump pully secure on its shaft? Perhaps remove the problem belt and check for loose pulleys or shafts.
Old Jan 25, 2010 | 05:33 PM
citcapp's Avatar
Sometimes it is not as tight as you think it is. hitch it up another notch. If not then John is most likley correct. Also bent or dented pullies will cause belts to jump as well
Old Jan 26, 2010 | 05:41 AM
Nako29's Avatar
I have a 1971 cutlass supreme with a 350 rocket,it has electrical fans.
Old Jan 26, 2010 | 05:46 AM
Welcome
Welcome aboard
X 2 on what the wise citcapp said
But, I don't have a clue why he called Rob "John"
Old Jan 26, 2010 | 06:03 AM
Bluevista's Avatar
Registered
Welcome to our humble home.
Need pics as usual.
Are all the brackets and the pump and alternator in the correct position with the right spacers and all that?
Could be a belt alignment problem like Beauregard said?
Old Jan 26, 2010 | 06:51 AM
Nako29's Avatar
Thank you . I will try that first
Old Jan 26, 2010 | 07:38 AM
Originally Posted by Nako29
My alternator belts keep popping ! I've noticed the belt jumps on the left side at the bottom,is that a steering pump problem or pulley ?
What car, what engine, what year, what options?
Old Jan 26, 2010 | 07:40 AM
citcapp's Avatar
Originally Posted by Jamesbo
Welcome aboard
Not enough coffee, not awake yet. Sorry Rob
Old Jan 26, 2010 | 09:38 AM
No prob, Buford...
Marks76442
Mar 19, 2014 11:01 AM
jackedolds
Nov 9, 2011 08:05 AM
misercola
18
May 3, 2010 03:39 AM
kimberlies7
Aug 28, 2009 03:03 PM
csouth
Jan 19, 2009 05:29 PM
