Grounding lug at PS bracket 67 442
I was looking at the assembly line manual the other night and it appears they want the fixed nut on the grounding lug outside of the PS pump bracket. I had it originally in the block with the nut sandwiched between the block and the bracket, only to take it all a part when I saw the wiring portion in the assembly manual. Now however there is a space between the bracket and the block if I DON'T have the nut between the bracket and the block. What is the order of installation here?
Regards
Regards
Regards
Regards
