Grounding lug at PS bracket 67 442
Old Oct 18, 2018 | 11:14 AM
NotDads442's Avatar
I was looking at the assembly line manual the other night and it appears they want the fixed nut on the grounding lug outside of the PS pump bracket. I had it originally in the block with the nut sandwiched between the block and the bracket, only to take it all a part when I saw the wiring portion in the assembly manual. Now however there is a space between the bracket and the block if I DON'T have the nut between the bracket and the block. What is the order of installation here?
Regards
Old Oct 18, 2018 | 11:40 AM
66-3X2 442's Avatar
Regards
The double stud goes into the block,then the P/S bracket fits over the stud & a nut holds the bracket to the stud. It's just as the PIM shows. If you have P/S and do not have the correct stud,it will leave a gap behind the bracket. On a non P/S car,a bolt is used for the cable attachment. The cable goes between the stud/ bolt & block which ever is required.
Old Oct 18, 2018 | 01:06 PM
Fpcopo's Avatar
So Mike do you have to remove the ps bracket to change the ground cable?
Old Oct 18, 2018 | 01:50 PM
66-3X2 442's Avatar
Yes unfortunately if you do it like the factory did. Of course you can ground it on the outside of the bracket but........
Old Oct 18, 2018 | 04:37 PM
Keep in mind that the ground wire was attached the same way whether that particular car got the optional power steering or not.
Old Oct 19, 2018 | 07:56 AM
NotDads442's Avatar
So to summarize it goes (block)(doublestud)(ground strap)(P/S bracket)(nut)?
Old Oct 19, 2018 | 08:49 AM
66-3X2 442's Avatar
block/battery ground/stud(bolt)/pump/no pump if not equipped.
69 Vert
Apr 29, 2018 06:25 AM
junior supercar
Jul 3, 2016 01:40 PM
Gary M
Jul 20, 2014 07:00 PM
hershillgn
Apr 3, 2012 02:34 PM
tnelson
Jun 24, 2010 04:59 AM
