GM HEI interchange???
Old March 16th, 2010, 06:39 AM
vettemad's Avatar
Hi Guys, just about done installing my new engine in my 70 toro, It came with stock points distributor, I've got a couple chevy hei's laying around and was wondering if they'd fit? anyone know the interchange on my 70 455?...thanks now!...cliff
vettemad is offline
Old March 16th, 2010, 06:44 AM
66400's Avatar
You need a core distributor from an Olds engine. 260/307/350/455
Henry
66400 is offline
Old March 16th, 2010, 07:57 AM
citcapp's Avatar
Olds to Olds only. The Olds unit runs counter clockwise.
citcapp is offline
Old March 16th, 2010, 08:14 AM
All GM divisions used different distributor bodies and drive gears. They are not interchangeable. Not only does the Chevy turn in the opposite direction (which by itself is not a problem), but the Chevy distributor body is longer and the oil pump drive shaft interface is completely different. Olds uses a hex drive, Chevy uses blade.
joe_padavano is offline
Old March 16th, 2010, 08:37 AM
vettemad's Avatar
OK, got it!... thanks guys!
vettemad is offline
Old March 16th, 2010, 02:22 PM
1964F85's Avatar
Hi Vette,
You might want to scope out the HEI units for sale on EBay.. I got one for my 330 for 55 bucks, including the shipping. I was surprised at how nice it looks and how well it appears to be made. There is no way to buy a junkyard Old housing and add all the replacement parts for this kind of money... The coil alone is almost 30 bucks.. food for thought anyway. I'm sure there are those who might balk at one of these, but I'm soon ready to drop mine in. I'll post the results when I do. Good luck with your project! Cheers, Mike
Here is the link to the one I bought..
http://cgi.ebay.com/ebaymotors/OLDSM...Q5fAccessories
1964F85 is offline
Old March 16th, 2010, 03:45 PM
vettemad's Avatar
not bad, and a possibility...thanks mike, cliff
vettemad is offline
Old March 17th, 2010, 02:51 AM
Yellowstatue's Avatar
Wink Dizzy
And due to the fact that the Ch**y dis turns opposite, the pick-up coil windings are wound opposite also and you cannot use them as back up parts...how do I know this... the plastic sheath for the pick-up plug is colour coded to ID the coil...black, white, yellow etc...six cyl., eight cyl., Ch**y, Olds...
Yellowstatue is offline
Old March 17th, 2010, 04:51 AM
vettemad's Avatar
Ok Guys, thanks for the input!....cliff
vettemad is offline
Old May 5th, 2010, 07:46 PM
Axeni's Avatar
Has anyone bought one of them HEI distributors from Ebay?
________
WEB SHOWS
Axeni is offline
Old May 5th, 2010, 09:28 PM
Proud Viet Nam Veteran
redoldsman's Avatar
This is from 1964F85's post on March 16th.
Hi Vette,
redoldsman is offline
Old May 5th, 2010, 11:08 PM
Jaybird's Avatar
I bought one. The price was right. When it arrived home, the box read... Made In China. F.Y.I.
I haven't tried it out yet.
I've heard that they have HEI distributers available that go inside of your old distributer. That would be interesting. I wonder if they have them for Oldsmobiles?
This question has been discussed here before. You might want to search the site for more info.
Jaybird is offline
joepenoso
June 4th, 2014 01:56 PM
jon1957
Brakes/Hydraulic Systems
April 11th, 2012 11:47 AM
oldscruiser
February 15th, 2011 12:44 AM
<Ryan B>
December 18th, 2005 07:02 PM
Jake Lydey
May 16th, 2005 06:52 AM
Quick Reply: GM HEI interchange???
