FASTEN SEAT BELT warning light option
Old February 21st, 2018, 06:21 PM
scrappie's Avatar
There is an option on some Olds cars I think in 1972? It is a seat belt warning light mounted on top of dash. How does this work and what is needed to install this? Does it work off a sensor in the seat and what else is needed? Is this reproduced?
scrappie is offline
Old February 21st, 2018, 07:34 PM
oldspackrat's Avatar
Those lights were only used on cars that had the optional Rally pack (Tach & gauges) AND that were manufactured after Jan. 1 of '72. There was a buzzer just to the right of the radio behind the dash & there was a seat switch/sensor mounted under the passenger side seat, bench or bucket. As far as I know it is not reproduced.
oldspackrat is offline
Old February 22nd, 2018, 06:37 AM
What Scott said. It wasn't an "option". It was federally required on all cars built after Jan 1, 1972. Regular Oldsmobiles had the light in the idiot light cluster. Rally Pac cars had the dash mounted light. Just out of curiosity, why would you want to retrofit one? What's the build date of your car?
joe_padavano is offline
Old February 22nd, 2018, 07:21 AM
2blu442's Avatar
I've also found these on the 1973 Cutlass. I'm not sure when they stopped this setup. John
2blu442 is offline
Old February 22nd, 2018, 07:56 AM
scrappie's Avatar
Thanks guys, the reason I ask is because I came across the dash mounted piece and wanted to know what else goes with it and its desirability.
scrappie is offline
Old February 22nd, 2018, 07:59 AM
Personally I think it is only desirable to someone who wants to celebrate excessive government regulation of our automobiles...
Old February 22nd, 2018, 08:10 AM
I remember seeing one of these in a car about 30 years ago. I'm like what the hell is that? I was still learning about these cars & had no idea why it was on the dash. I think it was a '73 or later car also. Same thing with the no vent dash pads. I first saw one in a '70 Cutlass, (F85) & was shocked to see a cutlass dash with no vents. I only owned a few Cutlasses at that point & was on the bottom end of the knowledge ladder.
Old February 22nd, 2018, 10:37 AM
I BELIEVE that that light was also used for the Vista's tailgate ajar option warning light.
Koda is offline
Old February 24th, 2018, 05:21 AM
mister442's Avatar
My Dad a 72 Supreme with buckets and console no gage pack and it had the fasten seat belt warning on the dash pad.
mister442 is offline
Old February 24th, 2018, 05:46 AM
Did he buy a new or used? It's very possible someone robbed the tach and gauges out of it before he bought it.
Old February 24th, 2018, 06:40 AM
mister442's Avatar
He special ordered the car from Drummy Oldsmobile in East Detroit Mi. in the spring of 1972
Old February 24th, 2018, 07:59 AM
oldsmobiledave's Avatar
Fyi
The seat belt warning light was ONLY mounted on top of the dash when the car was equipped with a Rallye Pac. The regular gauges had their own. No Rallye Pac then no warning light on top of the dash.
oldsmobiledave is offline
Old February 24th, 2018, 08:39 AM
Paladin31's Avatar
Koda & Dave are both correct, the 73-76 Cutlii only received the top of dash 'Fasten Seat Belts' lamp assembly with the U21 [Rallye gauge option], or the S/W got the 'tailgate ajar' lamp, obviously different lenses & harness but same housing appearance.
Brett
Paladin31 is online now
Old February 24th, 2018, 11:27 AM
stevengerard's Avatar
I also don't understand why it is not connected to a driver seat sensor. If the car is in motion, chances are there is a driver in the driver seat but it only has a sensor on the passenger side. Interestingly it only sets the buzzer off if the car is in drive and the passenger seat belt is unbuckled. You don't have to buckle the seat belt just pull up the male end a few inches and it shuts off the buzzer.
stevengerard is offline
Old February 24th, 2018, 01:34 PM
scrappie's Avatar
Costpenn is doing his thing on a 70 and he showed the buckets that were in it from 72 and the seat has the sensor for weight I'm guessing?
scrappie is offline
Old February 24th, 2018, 01:50 PM
That is a driver side bucket, the sensor was only on the passenger side in '72.
jja18
September 12th, 2017 10:34 AM
DennisG.
July 19th, 2014 04:48 PM
pops1958
July 8th, 2011 08:50 PM
bigblockolds
June 21st, 2011 05:50 PM
Olds luvr
July 14th, 2010 08:07 AM
Quick Reply: FASTEN SEAT BELT warning light option
