Dual Gate ID
Old Feb 7, 2016 | 11:57 AM
marxjunk's Avatar
Dual Gate ID
I got a bunch of parts out of an estate and the thing i cant figure out is what this dual gate application is for..it looks like 68-9 H/O to me... but the mount brackets dont seem right..any ideas? I want to ID it then offer it for sale...i am just unsure..it has the 67 GTO style top plate...an Oldsmobile shift arm..but there a bunch of details i dont recognize..it has what appears to be a GM style neutral switch etc...
Old Feb 7, 2016 | 12:13 PM
Paladin31's Avatar
Hurst DG
Mark this is the only pic I have of the 69 HO DG
Brett
File Type: jpeg
Old Feb 7, 2016 | 12:20 PM
timholliday's Avatar
Member
Looks like '68 H/O dual gate. Brackets could have been modified for other application.
Old Feb 7, 2016 | 12:23 PM
Appears to be either early H/O or Yenko. Pontiac units typically used a straight stick, not the "dogleg" stick.
Old Feb 7, 2016 | 12:30 PM
marxjunk's Avatar
thanks Brett..and Tim and Joe...mine doesnt have the burl wood applique i really thought it was a H/O..
the brackets appear to be a manufactured part..not something someone made up..its too clean and machine made..
i looked at 68 brackets and they hang off on the drivers side more than these....i was thinking 68-9 but then my mind wandered and thought later...this thing is tall..and thats why i thought the 68-9..
STUPID question..does 68-9 use the same shifter and mini-console...i dont remeber right now
i have 67 GTO and a 68 GTO and a 70 cutlass...but this thing is tall..those are shorter..
OR;;is it an aftermarket piece for some other console app? i am just unsure..ive never seen those mount brkts
Old Feb 7, 2016 | 12:35 PM
Member
68 and 69 H/O consoles are the same other than top plate. 68 is straight grain, 69 is burl. As Joe said it could be Yenko brackets. GTO DG looks similar but definitely different.
Old Feb 7, 2016 | 12:37 PM
marxjunk's Avatar
i see..i own a 67 and 68 GTO Dual gate..i have GTOs..and i recognize the the bent arm as cutlass..
Old Feb 7, 2016 | 12:41 PM
Member
'68 and '69
Old Feb 7, 2016 | 12:47 PM
Yenko cars used the same mini-console as the 68-69 H/O.
Old Feb 7, 2016 | 12:49 PM
marxjunk's Avatar
i see...wasnt aware..they say on 30 yenkos where autos..so not many around to compare
Old Feb 7, 2016 | 01:00 PM
Used in Chevelles and Camaros:
Old Feb 7, 2016 | 03:55 PM
marxjunk's Avatar
looks like its 67-9 Camaro or firebird...the camaro floor hump is flat and would make sense to me..has the right wood grain pattern for a 69 Yenko...lol...but who knows...
i am still leery to call it camaro..but hey..i guess it is..i was hoping Cutlass..
thanks for all the help and pics
Old Feb 7, 2016 | 08:48 PM
oldspackrat's Avatar
Some mid to late '70s Camaros used (probably aftermarket) dual gate shifters. I found one in a yard a long time ago. Just the top plate was there, shifter was gone. Your original pictures are not showing up now?
Old Feb 7, 2016 | 09:23 PM
hurst68olds's Avatar
pics are not currently showing, but
HURST sold Dual-Gate shifters thru the aftermarket with different brackets for just about every mid/late '60s performance oriented automobile.
The Dual-Gate & console that made its way into '68-'69 H/Os, Yenkos, '68 Super Stock Darts & Barracudas is this same "bent-lever" aftermarket version with body specific brackets, shift cable & "trim-to-fit" consolette (Olds & HURST just got a little fancy with the burled wood insert on the top plate for the '69 H/O).
IIRC Dual-Gate II came out for and is what was used in the '70 & newer 442, aftermarket & others.
Are there any numbers on the brackets?
Old Feb 7, 2016 | 09:30 PM
I have a NOS unit here - the top plate is (intentionally) missing the step between Reverse & Neutral.
The brackets are pretty tall and are just a little off for '68-'69 H/O (GM a-body) front #s 5717 & 5716 rear # 5718
Old Feb 7, 2016 | 09:41 PM
best pics I could find ..... and some H/O bracket pics
Old Feb 8, 2016 | 05:33 PM
marxjunk's Avatar
what the heck..the link to my pic is broken..i will deal with it when I get back to KCK
Old Feb 9, 2016 | 12:40 AM
I guess the brackets on my Dual Gate are for '66-'67 MOPAR b-body. I wonder if these instructions are from '67 and/or if there are different brackets for '68-'70?
pcard
Apr 7, 2012 07:21 PM
DanMan82
Jan 15, 2008 11:09 PM
Chuck C
Dec 7, 2004 10:14 AM
