Degree a cam
Old Jul 21, 2009 | 10:40 AM
scrappie's Avatar
Degree a cam
I have been following a post about a 425 with less than expected power. One of the topics discussed is to degree a cam. I must admit I have never done this. I have put together a couple Olds engines (350, 455) both times I had the heads done and put the rest of the engine together myself including bearings, seals, rings and cam installation. When I installed the cam I just followed the directions that told me to line up the dots on the timing chain gear and crank gear. I then got the #1 cylinder to TDC on the combustion stroke and inserted the distributer with the rotor as close as possible to the plug wire connection on the dist. cap. I then connected the rest of the wires according to the firing order. I then try to start with the dist a little loose and adjust as necessary to get it to fire up. I then set the timing according to the tune up specs.
I have never degreed a cam. What exactly is it and did I do it wrong?
Old Jul 21, 2009 | 03:04 PM
88 coupe's Avatar
Junior Member
Originally Posted by scrappie
........ One of the topics discussed is to degree a cam ........
http://video.google.com/videoplay?do...95865478396890
http://video.google.com/videoplay?do...41611176015126
http://video.google.com/videoplay?do...69278091943082
Norm
Old Jul 21, 2009 | 03:55 PM
jensenracing77's Avatar
Norm, i can't get the links. it may be on my side, i still don't know computers very well.
Old Jul 21, 2009 | 03:58 PM
ent72olds's Avatar
Registered Luser
same here
Old Jul 21, 2009 | 07:17 PM
citcapp's Avatar
YooHoo Norm, the links are not working
Old Jul 21, 2009 | 11:02 PM
88 coupe's Avatar
Junior Member
https://classicoldsmobile.com/forums/85491-post2.html
Norm
Old Jul 22, 2009 | 03:11 AM
scrappie's Avatar
Thanks for the links, I am beginning to see the light.
hotrodpc
Jun 21, 2021 06:38 AM
boondocker
Dec 22, 2010 02:35 PM
nickd
Aug 18, 2009 02:36 PM
DennisG.
Jun 14, 2008 12:18 PM
rt38 classic engines
May 9, 2006 05:28 PM
