cooling fan?
Old Nov 26, 2016 | 02:38 PM
kad36's Avatar
cooling fan?
Anyone tell me what higher output fan I can put on my 1949 88 with stock radiator and engine? I want better cooling so if anyone has a suggestion I will appreciate it...thanks, kad36
Old Nov 26, 2016 | 03:05 PM
What temps is it running now?
Old Nov 26, 2016 | 05:46 PM
kad36's Avatar
With cooler weather here on the desert it is fine...it's when the weather warms up over 100 degrees that the car gets hot with the a/c on and sometimes boils over...I am thinking maybe a five blade fan will help? Don't want to put an electric fan on this 6 volt system...The four blade fan doesn't seem to move much air even thou there is a shroud...
Old Nov 26, 2016 | 06:47 PM
What temp is it getting to when the outside air temp is over 100 and the A/C is on?
Old Nov 26, 2016 | 07:03 PM
redoldsman's Avatar
Proud Viet Nam Veteran
Where the heck did you find a 6 volt air conditioner? You can go to Speedway Motors and get a 6 blade fan that will fit. You will need to know the diameter of your current fan. A fan shroud will help a lot if you can find one. I have one off a 1952 model but it is promised to a member on here from England. You may want to check the condition of the radiator also. After I put the AC in my 54 I spend a lot of time (and money) getting it to cool down. I wound up have the radiator re-cored from a 2 core to a 3 core and adding an electric fan with a shroud. I still don't think it runs as cool as it should but it stays at 200 or below.
Old Nov 27, 2016 | 04:25 AM
kad36's Avatar
I'm not sure what the exact temp is when it runs hot but the needle on my temp gauge pegs and the coolant pukes from the overflow tube...The 6 volt cooler was installed at the dealer back in the day... I don't want to put an electric cooling fan on the radiator as I feel this will be more than the 6 volt system can handle... I already have two Optima 6 volt batteries side by side in the battery tray but still have the original puny generator. I will look into Speedway 5-6 blade fans, thanks...kad36
Old Nov 27, 2016 | 05:49 AM
As Glenn said above you may also want to consider having your radiator tested and possibly re-cored to a larger capacity. Talk to a local radiator shop.
Old Nov 27, 2016 | 08:00 AM
redoldsman's Avatar
I made a typo on the fan which should be 6 blade. The 53 and later cars with factory air had a water pump with 8 blades on the impeller rather than 6. These pumps would fit you car. It might help a little.
Old Nov 27, 2016 | 01:32 PM
kad36's Avatar
Back in the day I had a 1953 Olds 98 with factory a/c and a Dynaflow trans couldn't drive it over 60 on hot days as the temp gauge would go out of sight...Was a nice car but couldn't get over the runaway overheating on this BadBoy...I will try a better fan first, my 88 already has a shroud but it still heats up ...might have to go to a new core?
Bee Saint Louis
Apr 13, 2025 08:28 AM
ratified442
Hurst/Olds
Feb 4, 2011 12:12 PM
VikingBlue
May 18, 2010 09:24 PM
ELECMAN
Nov 23, 2009 02:19 PM
woodie582
Sep 7, 2008 09:25 PM
