Convertible Top Boot Installation
Old Nov 1, 2025 | 12:48 PM
Rokjhn's Avatar
I want to install a boot for the convertible top on my 1972 Oldsmobile Cutlass Supreme Convertible and see that there are two options for connecting the boot to the vehicle. I’m looking for some clues on which one I need for my car as I don’t believe it’s ever had one installed. Here are the two Options Offered:
Here are pictures of what I have:
Top of the trunk deck chrome
Bottom of the chrome piece
channel attached to back seat.
Hate to order one and have to send it back? Anybody have pictures or drawings of whether I should use 16 metal clips or plastic sliders?
Old Nov 1, 2025 | 01:33 PM
ben442's Avatar
This is what the plastic slider looks like. A good clean finish. Easy to put on and it stays on.
Old Nov 1, 2025 | 02:32 PM
Ben provided excellent images. I have the slider type, as well. Not specifically created to demonstrate top cover, yet there is decent coverage in this video of my '71 top cover.
Old Nov 1, 2025 | 02:51 PM
Rokjhn's Avatar
Looks Great! I’m curious if the slider or the clips are interchangeable or does it require a unique chrome piece on the trunk deck?
Old Nov 1, 2025 | 02:52 PM
Rokjhn's Avatar
Old Nov 1, 2025 | 03:19 PM
ben442's Avatar
The original boot I had was with the clips, half were broken or missing. That top boot got thrown away a long time ago. The chrome molding on the car has never changed.
Old Nov 1, 2025 | 03:22 PM
I don't know if slider & clips are interchangeable - I suspect they are not. I believe/suspect the pinchweld molding is specific to a convertible.
Molding, Pinchweld, 1968-72 A-Body Convertible, Complete Set, Finished Ends
Old Nov 1, 2025 | 03:41 PM
I'll provide several images. I call the leather/vinyl piece attached to the top cover a bead molding. The bead molding slides into the channel, which you already have installed behind the rear seat. You require four (two/side) snaps to secure the top cover.
I've found if you spray in the inside of the top cover channel w/ silicone it makes it far easier to slide the bead molding in/out.
Top cover channel
Top cover channel
Top cover channel
Top cover channel
Bead Molding
Bead Molding
Snaps
Snaps
Old Nov 1, 2025 | 04:31 PM
Rokjhn's Avatar
Where did you buy the boot from?
Old Nov 1, 2025 | 04:44 PM
I did not buy a boot (top cover). It was on car when I purchased (2018). Not certain if it was the original OEM. I suspect it was since that color is a one color only for 1971 (but again, I'm not certain).
Old Nov 1, 2025 | 04:52 PM
There are many manufacturers. I like PUI & Legendary.
You can try:
https://www.profitautointeriors.com/...6292/68AT.html
Old Nov 1, 2025 | 05:37 PM
ben442's Avatar
legendary auto interiors for mine
Old Nov 20, 2025 | 04:24 PM
Rokjhn's Avatar
Boot installed and looks great!  Thank you Convertible Top Guys!
Old Nov 20, 2025 | 05:59 PM
It would be nice if you stated where you purchased the boot (top cover) so others can learn.
Old Nov 21, 2025 | 04:00 AM
Rokjhn's Avatar
I thought I did? Very Happy with the support and product.
https://www.convertibletopguys.com/
Old Nov 21, 2025 | 04:20 AM
Thanks.
lala5818
Aug 8, 2023 03:46 PM
PatL
Aug 30, 2019 10:25 PM
brandon reynolds
Aug 25, 2019 03:28 PM
hansumtoad
Jul 30, 2016 11:39 AM
HouTXCutlass
May 10, 2009 07:09 PM
