Carb identification
Old Jul 25, 2019 | 04:39 AM
rickw30's Avatar
Carb identification
Can anyone help me identify this carb ?
I know it's a '69, but for what application ?
What's up with the full # (7029251) and no date code ?
Any help would be appreciated.
Old Jul 25, 2019 | 05:04 AM
allyolds68's Avatar
69 400 & 455, automatic trans. The date code might be on the base plate
Old Jul 25, 2019 | 05:16 AM
rickw30's Avatar
Thanks.
Does that include Toros ?
I have had this carb for over 35 years stored in it's original carb box. It looks as if it was never used, at least I never mounted it.
If it was original shouldn't it have the gold colored plating ?
Old Jul 25, 2019 | 05:44 AM
allyolds68's Avatar
Thanks.
the Toro is a 7029252 and the throttle linkage is different
What's the date stamped on the base plate? There were a lot of 69 service replacement carbs that were manufactured in the 70's. I had a 7029253 that had a 75 date code
Old Jul 25, 2019 | 05:47 AM
rickw30's Avatar
I will check and report back.
Old Jul 25, 2019 | 07:54 AM
rcorrigan5's Avatar
Randy C.
Some of the '69 "7029251 RJ"carbs simply did not have any kind of date code. I have both a '68 4-4-2 and a '69 4-4-2 and have inspected several carbs for both years. All of the '68 carbs I saw had date codes stamped into the base plate. I never saw a date code stamped into the base plate on a '69. There were some '69 carbs that had date codes with abbreviated carb numbers ("29251 RJ") stamped into the normal positions but that's it.
Randy C.
Old Jul 25, 2019 | 08:42 AM
allyolds68's Avatar
Randy C.
Randy knows 69 stuff a lot better than I do so I defer to him on this for sure.....
Old Jul 25, 2019 | 09:39 AM
rcorrigan5's Avatar
Randy C.
Rick,
To answer your question, the 7029251 RJ carb was used on the 1969 4-4-2 model with automatic transmission (except for the W-30 and W-32) as well as on all '69 Hurst/Olds. That looks like a pretty darn nice carburetor that you have! I'm not sure about the gold-colored plating or if it was ever there...maybe it just faded away over the years?!
Randy C.
Old Jul 25, 2019 | 10:03 AM
rickw30's Avatar
Thanks guys and thank you Randy for the info.
I own a 70 W30 and I am not that good with the numbers of other years. I will take a closer look and post pics of entire carb for closer inspection from those who may know more than me.
Thanks again
Old Jul 25, 2019 | 01:51 PM
Randy C.
I don't know, Randy. It's hard to tell from that one photo, but it almost looks like the carb was painted when it was rebuilt.
scottv442
Oct 14, 2017 09:55 AM
dnmfranco
Dec 9, 2015 01:25 PM
stonecad
Feb 28, 2014 08:22 PM
Indy_68_S
May 4, 2011 05:56 AM
slick50
Apr 1, 2009 08:09 PM
