Base Timing for 1965 442
Old May 29, 2026 | 05:59 AM
1arunem's Avatar
Reinstalling factory type distributor (from a 1972 Cutlass) with Pertronix conversion in my 1965 442 with 400ci.
What is a good suggested initial base timing to start with (with vacuum line off of course)?
Thanks in advance!
Old May 29, 2026 | 09:22 AM
The stock setting for a 65 400 is 7.5* @ 850 RPM where as a 72 distributor it's 8* @ 1100 RPM both set with vac advance disconnected. The 2 curves are a bit different and what I would do is set the timing to 34* at the RPM that the distributor stops advancing and let the initial be whatever it winds up after that. Then make a note for future reference what that initial timing is when done. You may have to limit the vac advance to 10* if it is bringing too much advance at light cruise.
Old May 29, 2026 | 10:00 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Then give it as much timing as it will tolerate without spark knock, which will eventually lead to tuning the vacuum and centrifugal.
I like the vac advance hooked to a full-time vacuum signal, not a ported port.
Old May 29, 2026 | 10:23 AM
VC455's Avatar
Barely Registered
...set the timing to 34° at the RPM that the distributor stops advancing and let the initial be whatever it winds up after that.
Best advice.
An easy way to do that without the high revs is to disconnect the advance springs, start the car, give it single low-rev bump to set the weights, and adjust the advance to 34°.
InfinityOlds
Jun 9, 2024 06:59 PM
starfire65
Jun 18, 2021 11:23 AM
1arunem
Sep 21, 2016 08:09 AM
1arunem
Jul 28, 2016 08:13 AM
classicmuscle442
Oct 12, 2014 07:22 PM
