Any knowledgeable welder/plasma cutter people in readerland?
Old May 31, 2022 | 12:36 PM
I have a Snap On plasma cutter. I bought it used probably 10 years ago. From tge research I have done, it’s based on Miller machine. I’m trying to locate replacement parts for the torch. There is a label inside the door with a Snap On part number for consumables, my snap on guy is having no luck with ordering them. The welding supply stores haven’t been any help either. Anyone know what I need to ask for? Thanks.
This is th me front panel of my plasma cutter
This is the label inside the machine for replacement consumables for the torch. The snap on guy says he can’t order them
Old May 31, 2022 | 02:02 PM
I find USAWeld.com is a good place to get consumables.
https://usaweld.com/pages/plasma_cutting_parts
Old May 31, 2022 | 02:21 PM
gear head's Avatar
ICE 27C consumables
Does your torch look like this?
Old Jun 1, 2022 | 02:48 AM
Originally Posted by gear head
ICE 27C consumables
yep, that’s exactly what my torch looks like.
Old Jun 1, 2022 | 03:35 AM
gear head's Avatar
You you have a ICE 27C torch. You should be able to go to any weld supply store and tell them you need a consumables kit for that torch or do an internet search for that torch.
Old Jun 1, 2022 | 06:37 AM
nicks1966's Avatar
Matt
That plasma cutter family is a convoluted mess, The machine was a joint venture between Hypertherm and Miller. Miller manufactured the machines in Appleton for themselves, Hypertherm, Snapon, Mac, Matco, Solar and Century. All machines used a Hypertherm manufactured torch ,they all looked the same and some even carried the same part number. The best part was that not all consumables were the same, if memory serves me correctly the o-ring, retaining cap and the tip could interchange between all the machines but the swirl ring and electrode would not.
I have seen snapon machines use snapon proprietary consumables, miller consumables and hyperther consumables depending on the machine and if the torch is original. I believe the miller will interchange with your plasma as long as the torch head has never been changes
Who is left in Kokomo for welding distributors, the old Mittler is now Praxair and I believe Airgas has a store , is there an Indiana oxygen or another independent to go to?
Try these Miller numbers
YA28142---169232
YA28143---202809
YA28144---176655
YA28145---176656
YA28146---202808
Call or text me if you have any questions
Old Jun 1, 2022 | 07:45 AM
gear head's Avatar
https://store.cyberweld.com/plcoki37...googleproducts
Old Jun 1, 2022 | 11:26 PM
Originally Posted by nicks1966
Matt
YA28142---169232
YA28143---202809
YA28144---176655
YA28145---176656
YA28146---202808
I tried both Praxair and Airgas, neither said they could match my parts. Maybe they really couldn’t, or didn’t want to mess with the hassles of the Snsp On/Miller halfbreed?
I have had this machine for probably 15 years, I don’t use it very often. There were a bunch of extra tips, o-rings, and other parts in the little storage compartment. It taken that long for me to use them. If I had know replacement parts would be this much of a hassle to find I would have searched and bought them much earlier.
Yerfathersolds
Aug 4, 2021 04:08 AM
yeahbuddy
Dec 7, 2020 05:21 PM
Copper Nine Eight
Dec 6, 2018 04:02 PM
OldsMotion
May 30, 2014 12:00 PM
Lars
Dec 7, 2013 06:42 AM
