Aluminum Radiator Repair
Old Nov 26, 2023 | 12:47 PM
Mr Nick's Avatar
The bolt for my overflow tank has been rubbing against the aluminum radiator. It did bore a decent indentation, but it does not leak. Only noticed it while doing some other service.
Even though it's not leaking, I'd like to be proactive and reinforce the area, my mind goes to a JB Weld (or similar) product.
Any suggestions?
Old Nov 26, 2023 | 01:16 PM
edzolz's Avatar
A very good welder could TIG that area to fill that void. I have welded air conditioner lines that had cracked and were leaking, that area would not be any problem.
Old Nov 26, 2023 | 01:47 PM
^^^THIS^^^
TIG welding is the proper way to repair aluminum. Either that or just leave well enough alone and cut a rubber insulator to go between the bolt and your radiator. I've used heater hose before that way by cutting it open.
Old Nov 27, 2023 | 07:09 AM
Hammerdrop's Avatar
There are some videos on YouTube using these aluminum brazing rods on AC condensers.
Amazon Amazon
Old Nov 27, 2023 | 08:20 AM
Doesn't even have to be a good welder... Is that the tank or support frame?
Old Nov 27, 2023 | 04:13 PM
Funkwagon455's Avatar
Three nicely placed dimes, good for a lifetime…😉
Old Nov 28, 2023 | 06:21 PM
Mr Nick's Avatar
Thanks for the comments.
It's the passenger side tank that has the damage. I've send JB Weld a message to see what they suggest. I'll probably just pull the radiator and have a local shop filler weld it. Years ago I had them pinch the aux heater hose nipple shut and weld it, since I don't trust the rubber block off caps. Weld looked good and has held up fine, hopefully the same guy still works there.
Old Nov 29, 2023 | 05:40 AM
BTW, what brand aluminum radiator do you have in your Oldsmobile?
Old Nov 30, 2023 | 05:26 PM
Mr Nick's Avatar
Northern Radiator, specifically 205055. https://www.northernradiator.com/Product/205055
Can be found a bit over $300
SLCJD
Jul 14, 2023 03:12 PM
57J2Olds
Jan 21, 2023 01:41 PM
72hardtop
Aug 22, 2017 01:54 PM
AZ455
Aug 9, 2016 11:47 AM
TCNakaya
Dec 25, 2012 01:27 PM
