adding fluid to the top motor
whats the easiest way to add fluid to the convertible top motor?do i fill it 1/4 inch below the filler hole?and when cycling it up and down do i leave the rubber grommet out of the filler hole?thanks
My weapon of choice is a condiment bottle (available at craft stores, etc) with a few inches of clear tubing on the nipple. Put a wad of paper towels down around the pump in any potential spill fallout area, stick the tube in the hole and gently squeeze, repeat until full. Cycle the roof and add fluid as necessary, when done, stick the plug back in.
(I've seen a YouTube video recommending ATF Dextron III or Mercon V for 2002 Mustang.)
