adding fluid to the top motor
Old Apr 28, 2022 | 11:21 PM
CleanCutt's Avatar
whats the easiest way to add fluid to the convertible top motor?do i fill it 1/4 inch below the filler hole?and when cycling it up and down do i leave the rubber grommet out of the filler hole?thanks
Old Apr 29, 2022 | 03:30 AM
bccan's Avatar
My weapon of choice is a condiment bottle (available at craft stores, etc) with a few inches of clear tubing on the nipple. Put a wad of paper towels down around the pump in any potential spill fallout area, stick the tube in the hole and gently squeeze, repeat until full. Cycle the roof and add fluid as necessary, when done, stick the plug back in.
Old Apr 29, 2022 | 04:20 AM
If you need to add fluid, unless you were just working on it, you have a leak. Mine was leaking at the left cylinder and going down making a mess under the seat/ door panel, etc.
Old Apr 29, 2022 | 07:55 AM
WTHIRTY1's Avatar
Escape From The Ordinary
Great idea on the squirt bottles. I'll have to check that out.
Old May 22, 2022 | 04:46 AM
Malcolm's Avatar
Do you know the type of ATF for a 70?
(I've seen a YouTube video recommending ATF Dextron III or Mercon V for 2002 Mustang.)
aslockcuff
Mar 28, 2023 07:11 PM
Doug69Cutlass
Jun 14, 2020 05:51 PM
Lyle_STL
Jun 14, 2020 10:02 AM
kens69olds
Jul 19, 2011 09:22 AM
