70 Motor Mount - Not The Usual One
I have read Joe P.'s excellent thread about the subject of A body motor and body mount combinations. My issue is a bit more complicated:
1) Car is a 1970 442 - was running when I got it
2) Car is (still) 455 equipped
3) Car has been "restored" before
4) Car has been completely diassembled for a resto
5) The car, after engine being removed had some frame straightening work done
6) I threw the motor mounts that were on the car in the trash at diassembly
7) The frame mounts that were in the car, that I cleaned and reinstalled, are the SBO ones. (I did not recognize them as such)
8)I installed the 2328's on the engine - not knowing the frame mounts are wrong for this car
So today
1) I tried to install the engine/trans in the car
2) Much cursing ensued
3) A few things were thrown
4) Some more cursing occurred
Bottom line, again, per Joe P.'s guide, if I was to install 2261 motor mounts on the engine I know the motor mount bolt would go through the mount and pad, but would everything work OK? Will the installed engine height be wrong and cause problems? (I.e. fan shroud clearance, OAI adaptor to hood clearance?) I Hope I didn't miss that part of the thread and get flamed, but at this point I don't care, flame away, just let me know if it will work. Thanks.
So today
Thank you Joe and Joe - From Joe!
It turns out the frame pad mounts that were on the car were the Type 1 64-69 version. I got a set of 2261's from O'Reilly's and they fit perfectly.
Incidentally, those mounts I bought were much better in appearance and construction than the usual Chinesium stuff you get from the big box retailers. Maybe a new supplier has been found because these had the metal "frame" the same thickness as an OE one I had, the rubber is not super shiny, etc..
