70 Motor Mount - Not The Usual One
Old Nov 1, 2018 | 06:24 PM
costpenn's Avatar
I have read Joe P.'s excellent thread about the subject of A body motor and body mount combinations. My issue is a bit more complicated:
1) Car is a 1970 442 - was running when I got it
2) Car is (still) 455 equipped
3) Car has been "restored" before
4) Car has been completely diassembled for a resto
5) The car, after engine being removed had some frame straightening work done
6) I threw the motor mounts that were on the car in the trash at diassembly
7) The frame mounts that were in the car, that I cleaned and reinstalled, are the SBO ones. (I did not recognize them as such)
8)I installed the 2328's on the engine - not knowing the frame mounts are wrong for this car
So today
1) I tried to install the engine/trans in the car
2) Much cursing ensued
3) A few things were thrown
4) Some more cursing occurred
Bottom line, again, per Joe P.'s guide, if I was to install 2261 motor mounts on the engine I know the motor mount bolt would go through the mount and pad, but would everything work OK? Will the installed engine height be wrong and cause problems? (I.e. fan shroud clearance, OAI adaptor to hood clearance?) I Hope I didn't miss that part of the thread and get flamed, but at this point I don't care, flame away, just let me know if it will work. Thanks.
Old Nov 1, 2018 | 06:38 PM
joesw31's Avatar
If the car has small block frame mounts, then, you need mount P/N 2261. And your shouldn't have any issues.
Old Nov 2, 2018 | 08:05 AM
Yes, 2261 mounts with those frame mounts put the crank centerline in exactly the same place as would 2328s with the other frame mounts. There is no difference in engine location. The only issue is that your configuration won't be "optically correct" for a 1970 442. It will be fine functionally.
Old Nov 3, 2018 | 06:50 AM
costpenn's Avatar
Thank you Joe and Joe - From Joe!
It turns out the frame pad mounts that were on the car were the Type 1 64-69 version. I got a set of 2261's from O'Reilly's and they fit perfectly.
Incidentally, those mounts I bought were much better in appearance and construction than the usual Chinesium stuff you get from the big box retailers. Maybe a new supplier has been found because these had the metal "frame" the same thickness as an OE one I had, the rubber is not super shiny, etc..
joe_padavano
Tech Editor's Desk
110
Jan 1, 2026 08:36 AM
ergot71
Feb 18, 2020 05:38 AM
JCMC64
May 26, 2017 10:04 AM
Jolly Green
Aug 3, 2015 07:30 AM
Se7enty5
May 12, 2015 08:48 AM
