69 olds 455 lansing built
Old May 14th, 2011, 09:48 AM
spartan442's Avatar
I picked up a 455 motor recently with a 69 block "M coded". Curious what it may have come out of. Has a 2 barrel intake and CA heads. Wondered if CA heads are any good, or look for a different pair for my rebuild. I can't seem to find much info out there on the heads.
spartan442 is offline
Old May 14th, 2011, 12:17 PM
It could have come out of any D88, D98, or Toro built in 1969. Assuming the 2bbl manifold is original, it's likely a 9.0:1 D88 motor. CA heads are virtually identical to C heads. Perfectly good heads to start with.
joe_padavano is online now
Del70
July 21st, 2020 11:42 AM
Octania
August 22nd, 2015 12:08 PM
4speed461
June 13th, 2015 11:58 AM
dfire25
November 22nd, 2013 05:11 PM
1970cs
September 19th, 2013 05:32 AM
Quick Reply: 69 olds 455 lansing built
