'69 Cutlass Air Conditioner warm air from right vents
The air coming out of the right hand vents is much warmer than the driver side. We take long trips and wife needs cooler air. Air flow seems the same but the center and right vents are 10-15 degrees warmer. '69 Cutlass Conv. with factory air. Looking for ideas before I tear into it. Thanks,
I can't think of any way the vents closest to the HVAC box would have warmer air than the vents farthest away, especially if the air flow is the same. The only thing that makes any sense to me is the ducts on the passenger side have holes or are not connected correctly to the vents, but that should result in less air flow.
WTony
February 20th, 2012 02:05 PM
