69' 455 eng.block
Old Apr 26, 2019 | 08:36 AM
SmirchIs#1's Avatar
69' 455 eng.block
I'm hoping someone can tell me what is max bore oversize on the 455.I have a 69' 455 that I thought was +.030,but when I showed it to a guy that was interested,I noticed .060 on the piston.The bores were not damaged when put in storage 10 years ago.As you can imagine the bores are somewhat rusty.If they don't clean up with honing,can it go to +.070 ? Thanks for any input
Old Apr 26, 2019 | 08:53 AM
OLDSter Ralph's Avatar
It depends how deep the rust and pits are, if they can be honed. The problem is going to get a set of pistons and rings. They most likely will be "special", and will cost more.
Old Apr 26, 2019 | 11:02 AM
Chesrown 67 OAI's Avatar
ask cutlassefi (Mark Remmell) . he will know how large of pistons you can buy without special order.
Old Apr 26, 2019 | 02:15 PM
cutlassefi's Avatar
4.190-4.195 are the next sizes. But you’ll either need to use a Pontiac piston and a different rod with those sizes, or get a special piston to use with your stock length rod.
Old Apr 26, 2019 | 05:02 PM
use that .060 over block for a boat anchor and get a block that can clean bore to .030 or .060.
that would be least costly approach!
gbledsoe3
Apr 28, 2015 02:36 PM
PHILATLAS
Jun 16, 2014 02:26 PM
perchhead
Mar 12, 2013 08:17 AM
455cutlass1969
Feb 24, 2013 05:14 PM
nonhog
Sep 17, 2010 05:34 PM
