Replacing pistons in a 455
Old Mar 10, 2013 | 12:56 PM
perchhead's Avatar
Can anybody tell me what i am going to bo looking at cost wise to have a machine shop take my old pistons off the rods and have my new ones pressed on. Just an avg. cost is fine just so i know.
Thanks, in advance
Old Mar 10, 2013 | 07:04 PM
64Rocket's Avatar
Why do want to change pistons ? You said that it had .040 over already.
Gene
Old Mar 11, 2013 | 08:04 AM
perchhead's Avatar
Gene
But they r low comp pistons in it now. Deep dish now
Old Mar 11, 2013 | 11:50 AM
DeltaPace77's Avatar
Sorry, but gonna be a little more involved than this. Since your new assembly is gonna be different weights than before, gonna need rebalancing, meaning the crankshaft has gotta come out. Also most piston/rod small end pins usually aren't pressed in, rather heated to expand, then slid in. Don't think the last part is gonna affect cost much. Just mostly the way it's done.
Old Mar 11, 2013 | 09:55 PM
64Rocket's Avatar
You are going to need a:
complete gasket set,
new rings,
rehone the cyl's,
hot tank wash block,
rod and main bearings,
rear main rubber seal,
MAW's
align hone mains,
Deck the block,
maybe more
Gene
Old Mar 12, 2013 | 08:17 AM
Do have one thing to add, if going from a rope to neoprene rear seal. Most rear crankshaft seal mating surfaces have gashes in them to help lubricate the rope. You don't want these with a neoprene seal, and need be mached off, unless you want even a bigger leak than the rope.
scooter123
May 24, 2014 10:59 AM
http
Apr 26, 2013 09:58 AM
Limey
Apr 15, 2013 10:45 AM
dartphil
Aug 9, 2012 06:54 AM
snowman
May 31, 2011 06:04 PM
