'68 442 400 c.i. Engine Bay Paint Types
Old Jan 25, 2020 | 05:15 AM
Stan Shinker's Avatar
Olds Yeller
Is there a sticky somewhere on the forum that shows the factory paint colors for the 1968 442 400 c.i. engine, accessories, and engine bay parts?
I'm redoing the engine and engine bay in my '68 442 and trying to keep it as close to stock as possible with just a few deviations like an aluminum intake manifold. Not sure if people use Eastwood engine bay black paint for brackets, etc.?
Any help is appreciated. Thanks!
Old Jan 25, 2020 | 08:47 AM
69 Hurst's Avatar
Olds Fanatic
Another member supplied this, I found it helpful. I used POR-15 Chassis Black for the frame and control arms, Eastwood's Under Hood Black for the firewall, core support, etc. with great results. I had my pulleys and brackets powder coated semi-gloss black for durability.
Good luck!
Old Jan 25, 2020 | 10:16 AM
Use that list with caution, as it is apparently a Chevelle list, not necessarily correct for Olds. For example, the "30% gloss" on inner fenders. Chevelles had metal inners. Olds has plastic that don't get painted. I've also never seen an Olds core support that was full gloss black.
Old Jan 25, 2020 | 01:33 PM
Olds Yeller
Thanks Guys.
I'm familiar with the A Body listing from when I've restored Chevelle's in the past, but wasn't sure of any other key differences for Olds.
I'll search the interwebs for some pics of original '68 442 engine bays to get some tips there too.
Old Jan 26, 2020 | 05:11 PM
69 Hurst's Avatar
Olds Fanatic
Good point Joe, I should have added that caveat to my post. I've been able to track down some of the Olds specific differences to this list. The core support is a perfect example, doing mine using Eastwood's Underhood Black instead of the gloss listed.
Thanks for the additional insight.
Old Jan 26, 2020 | 09:20 PM
The G block 400 was painted a bronze, and I think there's a Mazda color that is close. Also, some of the repop places like Fusick are close.
Old Jan 29, 2020 | 01:21 PM
Olds Yeller
Should the crankshaft balancer be painted black or the bronze color? I'm not sure if it would have been painted on the engine at the factory or if it would have come in black for assembly from the supplier.
Feb 7, 2019 04:31 PM
Kace
Sep 17, 2015 03:33 AM
kansjfr
Aug 18, 2015 06:25 PM
Draven
Jan 19, 2012 08:37 AM
442olds68
Oct 2, 2010 09:18 PM
