67 442 fuel pump NON AC car
You can't find a two port pump for your application because the factory pump for the 1967 442 was P/N 6416836, rated at 6 psi and having three ports. That is also AC 40523. All 1967 442s, with or without A/C, came with fuel return and a three port pump. This is shown in Figure 8-2 of the Chassis Service Manual. Are you sure there isn't a fuel return line somewhere on the frame rail?
By the way, a two-port pump would be P/N 6416835, also AC 40522.
The factory pump for the 1967 442 was P/N 6416836, rated at 6 psi and having three ports. That is also AC 40523. All 1967 442s, with or without A/C, came with fuel return and a three port pump. Are you sure there isn't a fuel return line somewhere on the frame rail?
I'm glad this topic came up. I was advised by a friend who use tobe a NAPA dealer and he said that mechanical pumps are getting hard to find. I checked Rock Auto and all they they listed for a 66 442 was an electric pump. I checked Summit for the Carter pump M4516 which is a great pump for the 66/67 442's and they said only 9 pumps left. I have no idea what's going on if what my friend said is correct but it could be that demand has dropped low enough that they have been discontinued. Take it for what it's worth.
I ordered it and yes, its now saying that doesn’t fit. Mike Richards is usually 100% spot on so I didn’t even look before ordering..I will text Mike tomorrow, he is probably sleeping right now. Hopefully it does fit
Andy - So to add on to Summit's comments, I believe they said it fit Old's 330, 350, 425, and 455. I bet the 400 not being included was just an error of omission, but better safe than sorry!
People need to really stop relying on third party catalogs as fitment guides. When it comes to Olds motor mounts, fuel pumps, water pumps, etc, the catalogs are nearly always wrong. Start with the factory parts book listing and cross that to other brands.
