64 Cutlass broken front door "Hold-Open" lever
Old Apr 13, 2023 | 06:52 PM
64CutlassConvt's Avatar
Hello Oldsmobile Forum, I have a broken "Hold-Open" lever (part name according to the GM Olds shop manual) on my 64 Cutlass driver door.
The two halves are still attached but the heavy duty 1" spring is missing.
Wondering is anyone has one of these levers for sale, perhaps from a parts car, or knows if this Hold-Open lever is available anywhere.
Also are these levers generic for the GM A-body cars of that era or Olds Cutlass specific?
Any insights or advice on installation greatly appreciated.
Thank you
Old Apr 13, 2023 | 08:56 PM
2blu442's Avatar
If I'm picturing this correctly I believe this is part of the door hinge. If that's wrong, would you be able to share a photo of the part you need?
Old Apr 14, 2023 | 06:23 AM
You are correct John. It is part of the lower door hinge. These hinges are common across all 1964-65 A-body cars, so repros are available everywhere.
Old Apr 14, 2023 | 06:24 AM
By the way, the spring itself is also available from the Chevelle repro houses.
https://chevelle.com/1964-72-chevell...e-spring-each/
mattking
Mar 10, 2023 07:36 PM
72cuttys
Oct 20, 2021 11:26 AM
jmos4
May 20, 2020 07:54 PM
dmcianfa
Body work
Oct 7, 2010 12:33 PM
