330-425 valve cover baffles
Old Mar 31, 2020 | 08:43 PM
Fpcopo's Avatar
I’m trying to stuff Harland Sharp 5016 roller rockers under my stock 400 valve covers. The baffle that runs from the end to the center hits big time. If I cut everything out but the center part of the baffle it will clear with 2 gaskets. I saw where 330 and 425s don’t have the end baffle. Could someone please post a picture of the bottom of one of these so if I can see if they will work? Thanks, Frank
Old Apr 1, 2020 | 07:21 AM
jmos4's Avatar
Hi,
My 455 Is getting built currently, 5016's and 65 valve covers, here's what Mark (cultasfi) had to do
Hope this helps
Regards,
Old Apr 1, 2020 | 07:46 AM
Fpcopo's Avatar
Hey Jim, could you please get me a picture of the rest of the valve cover? It looks like he modified the center of the baffle on the other side. I would like to see what he did. Thanks much, Frank
Old Apr 1, 2020 | 08:02 AM
jmos4's Avatar
Hi,
He's already got the valve covers installed, with 2 gaskets, he mentioned something about baffled grommets
sorry I couldn't be more helpful, maybe give Mark a call or pm and he can tell you all that needs to be done
Regards,
Old Apr 1, 2020 | 08:38 AM
Fpcopo's Avatar
Thanks for the pics Jim!
Old Apr 3, 2020 | 02:46 AM
Schurkey's Avatar
Pop four holes in the baffle for the tall adjuster nuts to poke through. I may have used a 3/4" hole saw. Solvent-and-compressed-air to remove the drill swarf.
Old Apr 3, 2020 | 05:54 AM
Fpcopo's Avatar
I had to cut the whole baffle out and bend the center narrower. The rockers smacked into everything and will touch the wall of the cover at full lift if I don’t use two gaskets. I know the covers weren’t designed for this but I am trying to keep it stock looking. I kind of figured this would happen so I tested it.
AK71CutlassS
Apr 26, 2017 11:51 AM
Kyle's 77 Cutlass
Jan 18, 2014 08:47 AM
Dapper 1956
Feb 10, 2011 08:00 PM
Jharken
Dec 13, 2010 08:34 PM
mgue67
Apr 28, 2010 10:27 PM
