Valve cover clearance M/T Cover
I've seen posted in the past there are shorter poly locks that should clear with a thick gasket. Sorry I don't have any personal expertise or part numbers for the shorter locks though. Maybe somebody else can chime in with a part number or link to the shorter poly locks.
Watch out machining 6-point poly locks
I did the same thing with some 6-point poly locks only to have clearance issues with the 6-point end down inside the rocker arm. I had to buy a set of 12-point poly locks and machine them down to clear the valve covers. The 12-point end fit inside the rocker arm with out interference.
Rodney
Almond900
Nov 1, 2016 09:29 PM
Almond900
Feb 26, 2016 02:56 AM
