Valve cover clearance M/T Cover
Old Apr 25, 2017 | 11:06 PM
AK71CutlassS's Avatar
I have M\T Valve covers. I have the .250 thick gaskekets from summit. It's seems like the rockers are still super close. What now?
Old Apr 26, 2017 | 02:16 AM
Its not the rockers that usually hit, the polylocks do. You can double the gaskets and gain a bit more clearance.
Old Apr 26, 2017 | 08:16 AM
bennie442s's Avatar
I had the same issue on my 70 Vista Cruiser. I took my polylocks to the machine shop and turned them down to a length where they no longer interfered with the MT valve covers.
-ben
Old Apr 26, 2017 | 08:20 AM
4speed455's Avatar
I've seen posted in the past there are shorter poly locks that should clear with a thick gasket. Sorry I don't have any personal expertise or part numbers for the shorter locks though. Maybe somebody else can chime in with a part number or link to the shorter poly locks.
Old Apr 26, 2017 | 10:39 AM
cdrod's Avatar
Rodney
Watch out machining 6-point poly locks
-ben
Ben:
I did the same thing with some 6-point poly locks only to have clearance issues with the 6-point end down inside the rocker arm. I had to buy a set of 12-point poly locks and machine them down to clear the valve covers. The 12-point end fit inside the rocker arm with out interference.
Rodney
Old Apr 26, 2017 | 11:39 AM
rpinnt's Avatar
I used a 3/8 a machined spacer from Ramairrestoration.com. It was enough to clear everything and barely noticeable (I cleaned the gasket material after photos, so even less noticeable now.)
Old Apr 26, 2017 | 11:51 AM
cdrod's Avatar
Rodney
Rpinnt:
That is one beautiful engine! I like your valve covers painted Olds gold in between the fins. Nice touch!
ROdney
Almond900
Feb 26, 2016 02:56 AM
MrLightning
Jun 5, 2011 06:39 PM
knighthawk
May 18, 2011 05:30 PM
Tony Cutlass
Tech Editor's Desk
Jan 17, 2010 06:36 AM
