Fremont built 1970 442 - Above where the emissions sticker goes on the radiator core top plate there are the remains of a yellow sticker.
Is this the engine cooling system decal? http://www.fusickautomotiveproducts....sp?number=DC43
Or possibly the CA emissions decal?
Is this a factory decal or something added by a garage later in life? See picture below.
Is there a height/width difference between these decals? It seems from the pictures that the version 2 (CB) decal is a little taller than the version 1 (CA) decal. I measured the outline of mine and it looks to be about 1 3/8" tall. Was there a particular date the version 2 decal started being used?
Is there a height/width difference between these decals? ... Was there a particular date the version 2 decal started being used?
Al,
My examples are 1 1/2" wide (camera angle was different).
That width checks with the remnant of the original that was on my car. Length varies 6 1/4 to 6 1/2" among my examples--the remnant is too tattered at the ends to check that; either could be correct.
I don't have much information on the version date ranges. When I lived in LA, I saw a version 2 on a Fremont car built in February.
My Lansing car was built on Jan 06, the second day of calendar 1970 production. It has the version 1 instructions, which are incorrect for the canister on the car. It has no funnel and the filter is meant to be changed, not washed.
Logically, they would change that label quickly.
Fremont could have started with version 2 or quickly transitioned to version 2. Fremont probably built more California-destined cars than Lansing did.
Did California sold Olds have the vapor line to the canister and fuel tank along frame like Buick did? My 1970 GSX was Flint built but California sold so it carried those things. There was a weird plastic vapor separator at the fuel tank that was held to the trunk floor by carriage head bolts. The floor of the trunk was even different than a 49 state car. There even was a small gold metal thing that looked like a flying saucer back there. Gas tank was unique to California sold as well. I restored it all. What a pain. Did Olds use similar set up?
Oh, yes. Total PITA. Three ports on the back of the gas tank to the vapor separator, and a line down the frame rail to the canister up front. And the carriage bolts through the trunk floor to hold that separator in place. Mine was built in Lansing but sold in Cali.
Cat,
The GM cars had similar systems for California emissions.
Some Olds models had a unique tank, some had the same tank with unique gas cap.
