Tail light LED wiring
Old Mar 17, 2021 | 04:55 PM
ragtopblue's Avatar
Evening all,
I am installing LED panels into my 1972 Cutlass Supreme tail light housings. The panels are connected directly by the bulb sockets. But there is a separate wire that is run to the dash which powers the sequential blinking pattern. The wiring instructions state that this wire needs to be connected to an ignition power source either wire or fuse block. Note the wire must be a non parasitic source.
Can any one recommend what would be the best power source, either wire or fuse block wise to use as my power source.
Old Mar 17, 2021 | 06:05 PM
Any one of the terminals in the fuse box labeled ACC or IGN. You just want a 12V source that is hot when the key is in RUN.
Old Mar 17, 2021 | 06:32 PM
Loaded68W34's Avatar
Here is the terminal you will want to connect to.
Old Mar 17, 2021 | 10:12 PM
ragtopblue's Avatar
Cool,
I actually have that open right now on the block.
Old Mar 18, 2021 | 06:35 AM
I wonder what they mean by non-parasitic. They're all parasitic. Maybe they mean not restricted to engine being running?
Old Mar 18, 2021 | 06:56 AM
I assumed that meant "full time power" as opposed to only being hot when the key was in RUN. If the load is connected to the battery all the time, it's a parasitic loss. Yeah, not the clearest way to word that, but the translation from the original Chinese was apparently difficult.
Old Mar 18, 2021 | 09:11 AM
Impeccable timing! I just finished reading the instructions for a backup camera I bought for my truck. Clearly, whoever translated or wrote the instructions does not have a clear grasp of the English language.
Big Dawg
Sep 26, 2018 04:49 PM
vickycar
Jul 13, 2018 07:13 AM
1968_Post
Nov 14, 2015 10:52 AM
Colpage1
Jun 22, 2015 08:19 PM
defiant1
May 10, 2010 12:57 PM
