1968 Olds Cutlass Adaptor Defroster Repair
I've had good luck making tabs out of PC7 epoxy putty. If it needs to have some strength, I embed a piece of wire in the original piece and mold the epoxy around the wire. Before it gets hard, you can trim with an X-acto to get the shape.
I just went through this with the ducting for my 67 Delta. I repaired it with two-part epoxy for plastic and fiberglass mat. Just be sure to rough up the original part and degrease with precleaner prior to bonding.
Thanks Joe. Did you use just the two-part epoxy? Or did you also use the fiberglass to fix your broken tab?
I basically wetted the mat with the epoxy and laid it up like you would with fiberglass resin. I used the epoxy for plastic instead of the resin because 1) it bonds better to the base plastic, and 2) it's more flexible than the fiberglass resin.
yeahbuddy
January 17th, 2011 11:20 AM
StickW31
January 21st, 2010 08:11 AM
