1968 Olds Cutlass Adaptor Defroster Repair
Old Aug 27, 2017 | 09:38 PM
jdana24's Avatar
1968 Olds Cutlass S
Any thoughts on the best way to repair the broken tab? I don't have the piece that broke off. Thanks.
Old Aug 28, 2017 | 07:52 AM
Indy_68_S's Avatar
I've had good luck making tabs out of PC7 epoxy putty. If it needs to have some strength, I embed a piece of wire in the original piece and mold the epoxy around the wire. Before it gets hard, you can trim with an X-acto to get the shape.
Old Aug 28, 2017 | 08:20 AM
I just went through this with the ducting for my 67 Delta. I repaired it with two-part epoxy for plastic and fiberglass mat. Just be sure to rough up the original part and degrease with precleaner prior to bonding.
Old Aug 28, 2017 | 06:16 PM
jdana24's Avatar
1968 Olds Cutlass S
Thanks Tom. I have some PC7 left over from restoring my steering wheel.
Thanks Joe. Did you use just the two-part epoxy? Or did you also use the fiberglass to fix your broken tab?
Old Aug 29, 2017 | 06:44 AM
From above:
I basically wetted the mat with the epoxy and laid it up like you would with fiberglass resin. I used the epoxy for plastic instead of the resin because 1) it bonds better to the base plastic, and 2) it's more flexible than the fiberglass resin.
Old Aug 29, 2017 | 10:48 AM
jdana24's Avatar
1968 Olds Cutlass S
From above:
Thanks Joe.
GTC
35
Jul 29, 2021 05:17 PM
boldts55
May 21, 2012 01:04 PM
1971
Oct 18, 2011 08:42 AM
yeahbuddy
Jan 17, 2011 11:20 AM
StickW31
Jan 21, 2010 08:11 AM
