Source for underhood vacuum "T's" and "Tree"
Old October 5th, 2015, 09:20 AM
Is there a source for the plastic T's and Tree for the underhood vacuum lines? I'm trying to help my buddy with his '70 442/4spd.
1969w3155 is offline
Old October 5th, 2015, 09:35 AM
brown7373's Avatar
Most parts stores in my area have plastic Ts in various sizes in the "HELP" section of parts. I was looking for brass ones and found lots of plastic, but no metal.
brown7373 is offline
Old October 5th, 2015, 09:46 AM
He already looked locally, but no luck.
Old October 5th, 2015, 01:31 PM
66-3X2 442's Avatar
I have a very nice vacuum tree from a 72 for sale if it's the same as 70. You can contact me @ pchopesq@aol.com
Mike
66-3X2 442 is offline
Old October 5th, 2015, 02:49 PM
marxjunk's Avatar
i have a bunch NOS..i have a few trees and a bunch of Ts in plastic and metal..i got them from the estate of a service manager..
they are in bags etc..and i can match them to pix and demensions if you have it
marxjunk is offline
Old October 5th, 2015, 03:26 PM
Olds Fever
CRUZN 66's Avatar
Advance Auto, Amazon.com, many other places as well, with various assortments.....
http://shop.advanceautoparts.com/p/d...ontent=9110158
http://www.amazon.com/s/?ie=UTF8&key...sl_1jc44m2en_e
CRUZN 66 is offline
Old October 5th, 2015, 08:52 PM
Mike & Marxjunk, I don't have manuals for those years, so I am not sure what is correct. Cruzn, he checked the local Advance Auto here, no luck. I'll look at the Amazon link. I believe that the tree was the one that he needed the most, as his is broken.
Old October 5th, 2015, 10:17 PM
70Post's Avatar
I believe there's only one plastic vacuum "T" used on that motor/trans combo and that's only if it's a car with the W25 OAI setup....the vacuum T that the flapper door vacuum motor hose goes to.
I have one here in black plastic that has a smaller outlet on the middle port of the "T"...makes it easier to plug in the smaller ID/OD vacuum motor hose.
Can't remember where I got the "T"...maybe a local auto parts store or maybe one of the larger auto parts chain stores. I'll try to figure out if it was one of the larger chains that may have a location in your area. If not, I probably have a spare one.
Pics below....the "T" and an example of the vacuum tree style you will need (not a spare or for sale)
70Post is offline
Old October 5th, 2015, 10:21 PM
Yes, the thermostatic vacuum switch is what is needed the most (the tree).
Old October 5th, 2015, 10:24 PM
He just acquired this car from his nephew, and most of the vacuum lines and connections were messed up, many not hooked up.
tru-blue 442
February 11th, 2015 05:29 PM
dnmfranco
December 6th, 2013 08:11 PM
69ho aurora
Hurst/Olds
March 26th, 2013 07:55 PM
pogo69
January 28th, 2013 03:49 PM
Phil Glass
May 29th, 2010 12:54 PM
Quick Reply: Source for underhood vacuum "T's" and "Tree"
